DSMLink - Worthless with the Evo?
Old Jan 5, 2012 | 02:30 AM
FJF's Avatar
FJF
Originally Posted by USCGSAM
...also some of the tuners in my area told me strait up that the time required to read the logs and make the adjustments for tuning is 2 to 1 for link and flash. they said dyno tuning w/ link should run around 500$ vs dyno tune w/ flash is 700$.
Those tuners in your area just did you a favor; they explained why you shouldn't let them touch your car.
Old Jan 5, 2012 | 05:05 AM
RelentlessEVO's Avatar
This is hilarious...and true.
Old Jan 5, 2012 | 09:00 AM
evo8426's Avatar
FJF to the rescue!
A dyno tune should not even cost $500 in the first place. You need to find better tuners because if they can not read logs from evoscan they must not be tuners. Ecuflash is very user friendly, why do you think there are so many "tooners"?
Old Jan 5, 2012 | 09:06 AM
Raptord's Avatar
I've never used DSMlink but I didn't find Ecuflash to be un-user-friendly when I was starting. There's lots of stuff to learn, but I imagine that's the case with any tuning software. And you can't beat the price...
Old Jan 5, 2012 | 10:09 PM
AWDBus's Avatar
There are tons of pro tuners on here that can do remote tunes. Unless you just have to have a dyno sheet with it they are way better then what it seams like your dealing with. If they find ECUFlash hard to work with I would look for other tuners. I cannot tune myself and I understand the basic workings of the software enough I could change it if needed (small changes).
Old Jan 6, 2012 | 04:29 AM
gsrboi80's Avatar
I about spit out my coffee
OP like others said ECUFlash, check out sticky threads in the Tuning/ECUFlash forum then pat yourself on the back
Old Jan 8, 2012 | 01:05 AM
USCGSAM's Avatar
From: Detroit metro area Michigan/Washington DC metro area
good point, i wasn't trying to drop names but since you raised this point it was Mach V Motorsports in sterling VA. I was out at their "open house" and was discussing options with them. The other shop in my area (DC/MD/VA) I still need to make a run to has a outstanding rep on here "Moore automotive". I am doing as much research as possible before spending any money.
real fast
AEM EMS
14
Nov 15, 2017 09:06 AM
Scottr126
Midwest Region
Jan 8, 2009 11:28 AM
logic
Nov 17, 2007 12:48 PM
Speedlimit
24
Oct 23, 2007 06:11 PM
