Anyone Put H.i.d On Foglights?
Old Dec 1, 2005 | 07:10 PM
WarmPepsi's Avatar
[QUOTE=EVOla_VIRUS][QUOTE=WarmPepsi]https://www.evolutionm.net/forums/sh...d.php?t=131358
and nevermind the negative people, or the people that whine about light everywhere.
agree...do what the f&ck u want....then find the whiners on this page at night and ride them with your low's and fog's on
i'm not sayin that, but mine are properly adjusted, per the manual (1 inch drop from center of housing (thats what that circle is in the middle of your headlight) @ 20 feet ). (might be 25 feet, don't remember).
there is no light that goes over the straight line. Meaning to HIT THE BEAM, and get a BLINDING SHOT. you'd have to be eyelevel with my car, and be one inch lower, in the oncoming lane, at 25 feet away, to get rocked.
I don't drive around on the street in a go-kart, how about you guys?
Old Dec 2, 2005 | 05:23 AM
yesevo's Avatar
how to adjust headlight? i tried to turn the adjusting bolt and it just keep turning and nothing happend/ is it because of the headlight adjusting motor which prevents from turning the bolts?
Old Dec 2, 2005 | 02:43 PM
WarmPepsi's Avatar
need to have it turned to the highest setting to adjust ( or so it tells you to, if i remember right, not sure if you really have to have it on the highest ).
also, make sure the tool you're using actually turns in, rather than is just sitting on top.
Old Dec 2, 2005 | 03:07 PM
whiteEv0boy's Avatar
if u dont mind ppl high beaming you opposite of you, go right ahead. Mines are HID and some people would turn their high beams on because the light shines everywhere. There is no way to adjust the beam because the light is not reflected or put through a filter. Its bright as hell, but does have its consequences. Make sure you get H11 and shoot anyone that tells you the fog lights are H7/
Old Dec 2, 2005 | 03:10 PM
Originally Posted by djmikeymike
unless this is for show it doesn't sound like a good idea.......... now hi-beams i would try..... do some searching and you will find a vender on here that sells HID upgrade kits
Why would you upgrade to HID hi-beams? It takes a few seconds for the HID to warm up. Unless you plan on leaving them on all night long ( which I doubt )
Old Dec 2, 2005 | 03:18 PM
Erik@MIL.SPEC's Avatar
Even if you do convert the fogs to HID, the fogs light up the car right in front, below the low beams. They shouldn't blind anyone with HIDs or without.
Old Dec 2, 2005 | 03:26 PM
GPTourer's Avatar
You don't want HIDs on your hi-beams. They take a second to warm up so if you flash to pass, or flash for whatever reason it doesn't react quickly enough. But it also wears them out faster. Most high end cars have HID low beams, but halogen high beams for this reason. A few cars have HID high beams, but then they'll have auxilary halogens just for flash to pass.
Fog lights are designed to aim down and illuminate the area right around the front of the car, but with no cutoff. I think an HID fog will probably spill out too much, but I'm not sure.
Old Dec 2, 2005 | 03:35 PM
djmikeymike's Avatar
i would like the hi beams becuase i live in the country and drive alot of back roads...... lots of deer
Old Dec 2, 2005 | 10:16 PM
SkyriseDavid's Avatar
Originally Posted by dookgvr4
I put hid's in my reverse lights.....it looks tight when I back up y0!
serious? Thats a tad 2 much for me :P But unique. I was planning on getting some 3000k fog lights. I think it would look clean. but thats just me x=
Norpothos
Lancer How Tos / Installations
Sep 15, 2015 05:40 AM
xbenbendx
Nov 17, 2013 06:13 PM
Jesus_Freak86
Sep 4, 2013 08:31 AM
kamel500
Oct 23, 2011 12:26 AM
jackbenimbo
Mar 2, 2011 03:40 AM
