Daily driven 400+whp Evo owners....chime in.
Old Dec 7, 2005 | 08:09 AM
evoviiiyou's Avatar
Actually it is not that bad. I only drive her on perfect, sunny, and dry days in the spring, summer and fall. She is an 03 with 1900 miles on her...plus I have a Honda Civic daily driver that gets 41mpg express way. I guess I could lower the boost, which would lower the out put, but my combo was put together with using 110 all the time as a primary factor. If I was going to run pump 93/94 octane, I would have used a different combo, or added a methor alky inj. system.
Originally Posted by Atlas
X_x
seriously? that must suck to buy that kind of gas all the time.
Attached Thumbnails Daily driven 400+whp Evo owners....chime in.-normal_evo8you-20176.jpg
Old Dec 7, 2005 | 08:15 AM
Black05evo8's Avatar
the stock turbo is the best....
Old Dec 7, 2005 | 08:18 AM
ct9a gsr's Avatar
Originally Posted by The Stig
The car leaves for the north next week, going to AMS to have some work done to it. I have spoke with the shop, and they have a laundry list of stuff to do to the car.
I guess my concern is, is the car going to be 'scary' for my wife to drive? Best guess is low boost is still going to be over 400whp, which will also be where I open-track the car at. High boost will be for viper/vette hunting at Road Atlanta, as long as the stock internals live.
Guys and Girls with the big numbers, how does the car drive, is it scary for the person who commutes, rather than drives?
Hope to see you at Road Atlanta next season... and btw, you don't even need 400whp to hunt down vipers and 'vettes (minus the c6z06) =]
Old Dec 7, 2005 | 08:25 AM
Derek888's Avatar
im running 26psi with methanol and I was wondering if I up the boost to maybe 28psi do I need to get another retune and will it be safe? Will the afr's stay the same at 28psi and at 26psi?
Old Dec 7, 2005 | 08:27 AM
ArchieBabes's Avatar
You need to get a retune for that 2psi of boost increase.
Maybe decrease timing a bit.
Old Dec 7, 2005 | 08:35 AM
Derek888's Avatar
thanks
Old Dec 7, 2005 | 09:41 AM
ChadB's Avatar
Sounds like loads of fun.. Watch out!!
Old Dec 7, 2005 | 11:06 AM
ct9a gsr's Avatar
I was tuned for roughly 28~29psi on the dyno but have spiked upto 32psi+ (on purpose) on the same tune without any problems while driving. How safe this is, I'm not sure... =]
Old Dec 7, 2005 | 12:06 PM
get faster's Avatar
Hey, it's all gonna be fine. She just has to drive without 'pushing the pedal for more'. No need to short shift as the turbo ONLY comes on under load anyways. In other words, you only get boost when your foot asks for it. My only thought is that the clutch may take some time getting used to (for both you and her) as I'm sure you'll be going with an upgraded one for this hp range.
Old Dec 7, 2005 | 03:25 PM
slickevo18's Avatar
i make 500+awhp, no problems! i have 2 maps, 20psi for daily and 30psi for race!!!! just stay outta boost if your that worried about it.....
Old Dec 7, 2005 | 06:09 PM
Ludikraut's Avatar
It's going to depend on what turbo you end up with. If your setup ends up spooling up after 3500 rpms, then it shouldn't be a problem to drive for your wife (as long as she keeps it under 4K). If you're going with a GT35R, the pump-gas spoolup isn't quite as violent as the smaller GT series turbos. The other concern I would have is surging in 5th gear ... if your wife drives on the interstate and decides to floor it in 5th gear while cruising at 65-70, the turbo may surge (aka, violent bucking)...
l8r)
Frocite
Aug 9, 2016 07:41 AM
Sticky MR
Dec 10, 2010 08:33 AM
daechul2da
Aug 28, 2010 04:11 PM
sly
Midwest Region
Aug 4, 2008 10:32 PM
Turbo_Saloon
Oct 17, 2005 06:39 AM
