Things Currently Broken on your Evo
Old Dec 22, 2005 | 09:13 PM
  #46
4TUN8's Avatar
Currently? Nothing mechanical, but paint on the calipers and clear on the wing are bad.
Old Dec 22, 2005 | 10:13 PM
  #47
4cefedgst's Avatar
Originally Posted by dubbleugly01
your noise may be a throw out bearing, I don't know. What I do know, is the stock Mitsu tranny makes a lot of gear noise. This is common problem reported by others. Go to a lightweight flywheel and it gets worse. Just ask the vendors who sell lightweight flywheels if you don't want to take my word for it.
In your case, what's making the throw out bearing move at idle? Just engine vibration? but why does that make the throw out bearing rattle? The pressure plate is only rotating, and not moving axially, the bearing itself is under no load, the release fork is stationary, why is the throw out bearing moving? So if I took a throw out bearing in my hand, and shook it, it should rattle?
Obviously I'm not going to convince you one way or the other. I can tell you I've been working on DSM's for almost five years (not nearly as long as most people) before I got the EVO and the TOB made noise in them too. When I changed the TOB in the DSM the noise stopped.
Old Dec 22, 2005 | 10:30 PM
  #48
RED DEMON's Avatar
30k no problems whatsoever. I have moderate engine modifications and decided to make sure my evo was one of the "strong batch" before i did some higher level performance packages. After winter, the evo will be a whole new beast!
Old Dec 22, 2005 | 10:45 PM
  #49
ThEyElLoWoNe's Avatar
need to roll my fenders (cant take a turn at 25 with 2 people in the car), need to weld up some exahust leaks from my cutout, wing is faded, need a tune, brakes!!!!!!, and a small crack in the windshield.
Old Dec 22, 2005 | 11:39 PM
  #50
FresnoEVO's Avatar
new advans, new clutch... $$$$
Old Dec 22, 2005 | 11:45 PM
  #51
EVIL_EVO_VIII's Avatar
Nothing here! *Knock on wood* Well except a bunch of paint chips on the hood and fenders and side of doors!!!!!!!!!!!!!!!
Old Dec 23, 2005 | 01:46 AM
  #52
Daman Wiseman's Avatar
03 GSR
35K miles
Drivers side seat plastic is cracked.
Tranny grinds going into fifth.
Brakes squeel like a stuck pig when they heat up.
Paint on brake calipers is bubbling. T
hat stupid floormat tack wont hold that stupid floomat.
Turbo outlet has a stripped out bolt hole(thanks to the STEALERSHIP).
Oh and I just went through my second motor in a 28 day period because the tech that installed my warranty motor didnt check for leaks when he installed it, so he missed the main seal leak that was starving the mains for oil at highway speeds.
Other than that I love my car. It handles better than anything I have ever driven and gets more looks than most anything I have ever owned.
Old Dec 23, 2005 | 03:48 AM
  #53
gqpenguin's Avatar
hmm got about 3k and the only thing that drives me nuts right now is the goddam rattle. Seems like it is coming from the climate control/radio area... its like a creaking noise when i drive on the freeway.
Any ideas?
Old Dec 23, 2005 | 03:57 AM
  #54
RedEvoInKy's Avatar
8200 miles on the 03', only issue was the TOB noise. 802 miles on the 06' MR, and the only thing wrong with it is that I haven't driven it more.
Old Dec 23, 2005 | 04:06 AM
  #55
smokedmustang's Avatar
Transfer case
Twin plate clutch
Triple plate clutch
Cusco swaybar bracket
Things CRACKED/BROKEN due to oil pump balance shaft being 180 out of phase
Alternator brackets 3
AC brackets3
Alternator 1
Serpentine belts destroyed 4
Aluminum pipe to AC (broke off) 1
metal nipple going to the brake resivoir (under air box) 1
oil pan cracked bolt to bolt 1
metal cover to clutch. cracked bolt to bolt 1
starter (going out now) 1
Other than that, fine with 56K miles on it.
Old Dec 23, 2005 | 04:30 AM
  #56
mrbkkt1's Avatar
chip on windshield, turbo timer(dropped something on my dash, but new one just came in, will install tommorrow), several rattles including afformention TOB one, a ton of paint chips( would it hurt to put 2 coats of paint on the hood?, but other than that, mechanicallly, very good so far.
Old Dec 23, 2005 | 05:27 AM
  #57
LIFER's Avatar
spun a rod bearing @ 20k miles w/100+drag run's
Old Dec 23, 2005 | 06:33 AM
  #58
pgjoey's Avatar
Originally Posted by poormansracecar
The only thing broke in my Evo is the Driver's side wallet. I also have an intermittent broken passenger that whines about going too fast in turns and such (this makes a loud schreeking noise (sounds like screaming then followed by a SLAP!).
Darn you Jhero23 , you beat me to it while I was afk lol
Hahaha...
18,000 miles - nothing, except the speed limit is broken almost all the time
Old Dec 23, 2005 | 08:57 AM
  #59
Dutch's Avatar
Number 4 Cylinder/piston
need a rebore, new pistons, new crank, and some valve work in the head, along with a replacement for the worn-out stock clutch (I made it to 30k miles).
Oh, and the worst of all: a cracked windshield.
(Note, sig reflects all I'm doing to bring car back to life.)
Old Dec 23, 2005 | 09:00 AM
  #60
DCSilvrEvo's Avatar
^^^^^ Ouch!
