Auto meter Boost Gauge ?
Old Dec 22, 2005 | 07:02 PM
gsrboi80's Avatar
Quick ?. Im installing my Autometer Boost Gauge with the single steering column pod. The autometer gauge came with nylon tubing that they say to use for the gauge is this what you guys used or did you use rubber tubing
Old Dec 22, 2005 | 07:08 PM
SterlingEvo's Avatar
I used rubber tubing all the way...
Old Dec 22, 2005 | 07:10 PM
gsrboi80's Avatar
Do you think it matters at all Im just curios cause I would have to pick some up
Old Dec 22, 2005 | 07:12 PM
shimla's Avatar
is there a how-to on this install?if there isn't one yet, could you make one?
Old Dec 22, 2005 | 07:14 PM
As long as it doesn't leak, it doesn't matter. I got a package of black rubber tubing from AdvanceAuto and it was long enough to go from my Profec up to the gauge in the pod, so I just used it. I don't think it really matters, though.
one note, make sure to buy the tubing in a size that will fit ultra-snug on the nipple on back of the gauge. Even that it's super hard to get on. That way you'll be sure it won't pop off...
gsrboi80's Avatar
Yea I fond one for the column pod and one for a boost gauge. I would Do a step by step tommorw but I wont have access to a camera
Old Dec 22, 2005 | 07:15 PM
romogst's Avatar
Nylon tubing is fine ,that's what i'm using for my boost gauge and works 100%
GTSMWET's Avatar
Rubber
Old Dec 22, 2005 | 07:16 PM
gsrboi80's Avatar
Yea the nylon tubing that comes with the gauge also comes with fitting to attach it to the nipple on the back of the gauge
Old Dec 22, 2005 | 07:20 PM
here's a good one from the how-to section (search it often, it is your friend )
https://www.evolutionm.net/forums/sh...ad.php?t=98114
Old Dec 22, 2005 | 07:51 PM
sandm's Avatar
used nylon at first, then swapped out for rubber about 3 months ago and the same reading. nylon is easier to hook up to the back of the gauge, but it seemed to be harder to tap into the boost line off the intake. I would use rubber again if I install on another car...
Old Dec 22, 2005 | 08:59 PM
Sgt Blamo's Avatar
I used the nylon tubing that came with mine on my Superduty (30 psi !) w/ no problems @ 100K miles since I installed it. I used copper tubing on my Evo, so either way, it shouldn't matter.
Old Dec 22, 2005 | 09:11 PM
EVOlutionary's Avatar
Just use the nylon. There is a reason Autometer sells it with that. There is a smaller inside volume to the nylon tube. It will read better, and quicker. Also, the nylon will not expand at all. Rubber lines can and will expand a little.
EVOlutionary
Old Dec 22, 2005 | 09:23 PM
yeah, use what came with it. I got gauges used from a wrecked Evo, so I had to buy the tube, and rubber was the fastest, easiest, cheapest.
