Aftermarket oil filters
Originally Posted by Derek Baker
Mobil 1: M1-108 or M1-110 I like the M1-110 its larger version. I don't like the Mitsubishi replacement filter you get at the dealer. The inside filter material is different than what my car came with from the factory. Mitsubishi decided to replace the original Japanese filter with a cheaper version that is all that is available here in the U.S.
Derek
Derek
Originally Posted by jk_addict
anyone heard anything bad about the Mobil 1 M-108? Auto-zone database said it should work, but I don't want to trust them. I'm putting one on now, I'll post if something bad happens
Originally Posted by mrfred
Mitsu also has a "severe service" maintenance schedule for the Evo. This sched calls for oil changes every 3.5K miles.
What is severe Service? And why is the oil change made every 3.5k and not 5k.
DENSO makes the OEM filters. You can order them directly from DENSO if you go to: http://www.densoaftermarket.com/
I bought a case of 10.
In the past, I've used the Pure One (very nice) and the smaller Mobil 1 (scary small.. I won't use that again, but I couldn't find the bigger one). I'll stick with the DENSO's.
I bought 5 of the OEM filters from South Coast Mitsu a few weeks ago since they're 30% off. I also use them with Royal Purple oil.
I'll probably switch to the purolator when i run out of these.
I use Mobil 1 (M104, almost the same size as stock), but after reading this thread I think I might switch to the Pure One (cheaper and more efficient). I just wish there was more independent testing that compares the aftermarket filters to the stock filter. Maybe I should hookup a pump and cycle oil through each filter and connect the output to a secondary filter to catch any debris that made it through the oil filter (fill the oil with the same amount of debris for each)? The cleanest looking secondary filter would imply the better filter.
Pale Horse
Jul 26, 2013 09:47 PM
