HKS RS intake, how bad is it?
Old Dec 25, 2005 | 04:30 PM
Z-Ball's Avatar
I was thinking about getting the HKS intake, but someone told me that these types of filters dont filter for ****. is this true, and what will happen in the long run with this intake?
Old Dec 25, 2005 | 04:33 PM
lvNVevo's Avatar
good looking intake. without a tune it was junk for me. i had big problems with it in the car with no tune. spend the 200+ on a reflash or something better than an intake. Search for more info
Old Dec 25, 2005 | 04:34 PM
EVO-8-Nate's Avatar
I love mine!
Old Dec 25, 2005 | 04:35 PM
EvoDan2004's Avatar
well i have this intake on an 03 evo. i dynoed 268hp and 265 trq with out a tune. also had fmic piping and bov. i love it. no problems here.
Old Dec 25, 2005 | 04:37 PM
Z-Ball's Avatar
hmmm. how often does the sponge filter gota be changed?
Old Dec 25, 2005 | 05:51 PM
sleet's Avatar
^ It depends where you drive, I did my first filter untill about 10k and it was still fine.
I bought another filter recently and washed the old one, worked perfect. Once this one gets dirty i'm going to put back in the old one and wash this one, then repeat the cycle.
I also ran this intake for a long time without a tune, never stalled once or lost any power.
Old Dec 25, 2005 | 07:25 PM
fellowx's Avatar
I love mines too. I haven't gotten it tuned yet but so far no problems.
Old Dec 25, 2005 | 07:32 PM
akEvo's Avatar
i swapped my buschur filter for an RS setup, i havent noticed a difference other than the sound, though i havne not been retuned
Old Dec 25, 2005 | 07:48 PM
MrMejia's Avatar
this will make you run like crap without a tune, your MAF readings will make you run pig rich and you will lose hp and mileage. Although, with a tune this is known to be one of the best intake systems on the market for our cars however....the filtration sucks. So this is why you have to change out the filter every 5k miles to avoid having foam pieces inside your turbo and exhaust system.
Old Dec 25, 2005 | 07:51 PM
akEvo's Avatar
if my car was tuned for the buschur filter, will the RS make or change that much, i wouldnt think so.... its not as a large of change than a stock airbox to the RS filter
Old Dec 25, 2005 | 07:58 PM
MrMejia's Avatar
the buschur cone filter does change MAF readings but not as dramatically as the RS suction kit. I believe you might want to check with MR. BUSCHUR himself. Go to the website and get the contact info to give him a ring. My guess is "yes" you would because the MAF readings change quite a bit with that RS system but call to make sure.
Old Dec 25, 2005 | 08:08 PM
sleet's Avatar
I have never heard of anyone having foam peices inside the turbo or exhaust.
Old Dec 25, 2005 | 08:09 PM
mooreboost's Avatar
They don't filter for crap.
Period.
Go knock out your stock filter and look at all the garbage that falls out. Then ask yourself if you would want all that stuff going through your engine.
Old Dec 25, 2005 | 08:10 PM
Jakeg97's Avatar
its one of the more popular intakes , cant be too bad
https://www.evolutionm.net/forums/sh...d.php?t=147111
Old Dec 25, 2005 | 08:14 PM
1Crazy8's Avatar
i would post a comment HOWEVER, i went a slightly different rout,
buschur maf pipe kit fabbed up with just the pipe no holes NOTHIN on it so its made specifically for VTA BOV and get it tuned ull be plenty happy...
