Really stupid problem
Old Dec 27, 2005 | 08:44 AM
Agent-Smith's Avatar
So my rear passenger window decided to give me the finger. The power window switch works from the actual door, however when I use the driver door controls the window does nothing.
Any clues as to how to fix this? (my car is out of warruntee and I would rather not have to pay for this.) I am pretty handy DIY'er with electronic fixes.
Old Dec 27, 2005 | 08:45 AM
puff n pass's Avatar
do the other windows work from the driver door panel?
Old Dec 27, 2005 | 10:11 AM
li1p1aya's Avatar
check to see if the switch actuates with a ammeter (driver door). if not, do a continuity test to see if you have a broken wire (mostly likely not though)
Old Dec 27, 2005 | 10:13 AM
housedj's Avatar
pull the whole door window controller out to see if maybe it came unplugged...
Old Dec 27, 2005 | 10:14 AM
evo_rc's Avatar
mine was doing this yesterday... when my passengers in the back manually lift the windows I cannot control them after that. So I had them lift the windows back up and I tried to bring them again and it worked. Is this normal?
Old Dec 27, 2005 | 01:15 PM
Yeah both switches can't be used at the same time. Also the drivers side controls works for all the other windows.
Old Dec 27, 2005 | 03:17 PM
get faster's Avatar
Easy fix for an AUTO ELECTRICIAN. That's my 2cents.
Old Dec 27, 2005 | 04:51 PM
Gonna pay for it
Old Dec 27, 2005 | 04:55 PM
J Dog's Avatar
Mine does this only because the rear passenger window control sticks. So I have to make sure it is not sticking in order for me to use it from the main window control. You may want to check to see if it is sticking down or up because you aren't able to use it from the drivers side if the rear is trying to work.
Old Dec 28, 2005 | 10:44 AM
walkedu's Avatar
i've heard of this before. I'd check into it.
Old Dec 29, 2005 | 07:11 AM
Matz's Avatar
So are you saying that if you have the passengers operate the window from the door, and you simultaneously try to move the window in the opposite direction from the driver door, the driver door input doesn't override the current mode of operation? i.e. if they are rolling it down, and you try to roll it up, does it keep moving down?
Old Dec 29, 2005 | 07:17 AM
bechbum82's Avatar
could be a stuck relay?? could of came unpluged. is that the only one that you are haveing problems with
Old Dec 29, 2005 | 08:29 AM
Nope the window just stops moving the 2 switches fight
Old Dec 29, 2005 | 09:41 AM
Matz's Avatar
But it doesn't do this on the other three windows? I would have expected this to be normal behavior. But if no one is in the car but you, and you roll the windows down from the driver's door, everything works, right?
