Which Fuse?
Old Dec 27, 2005 | 11:26 PM
MitsuEvoIIX's Avatar
Question Which Fuse?
Ok i was installing sirius radio that i got for xmas and i had to wire a power n ground so i used the same points i used for my gauge which was the power on the radio harness and a ground to the beam behind the radio. Everything worked and i was all good and i go to put the face back in which is a pain in the "butt" b/c of all the wires and tape came off the power and i blew a fuse. I checked all the fuses and they seem to be good except the 2 under the hood with the yellow clip. My interior lights dont work, power locks, windows or radio, can anyone help me?
Old Dec 28, 2005 | 07:59 AM
kataklyzm's Avatar
more than likely its the two under the yellow clip since when you pull up on the clip, it will turn off power to basically everything but the engine. the clip is for going on long trips and leaving you car at home, so you dont come back to a dead battery
Old Dec 28, 2005 | 08:10 AM
how do i get the clip off?
Old Dec 28, 2005 | 09:03 AM
got it off...and it was that fuse
Old Apr 8, 2006 | 06:24 PM
jm131994's Avatar
Lightbulb Thats it.
I had that problem as well. It was that fuse in the yellow thing.
Thanks
Old Aug 24, 2011 | 06:33 PM
jbenosa's Avatar
can someone pm me and advise how they tooks those fuses out? i see plastic pieces on both the top and bottom and it seems like you have to break those off to remove the fuses. my radio isn't working and i need to check that radio fuse in that yellow clip. thanks in advance!
turbotaloon95
May 16, 2017 01:57 PM
daniel007
Jul 29, 2015 06:29 PM
80210
May 27, 2012 10:55 PM
cpunlamd
Jun 20, 2010 06:25 PM
evo86
Sep 27, 2005 11:25 PM
