Are you driving around with your plastic underpanel?
Old May 22, 2013 | 05:59 PM
  #166
4drboost's Avatar
Nope, I'm currently using Beatrush undertray
Old May 22, 2013 | 06:41 PM
  #167
deeman101's Avatar
The trick to those clips is 2 flatheads on either side of the middle part to pull that up a little, then this tool will pull the clip out with ease. Without ruining the clips as often.
Also works great for pulling coil plugs out, popping interior panels, etc.
Unfortunately those garbage undertrays are easily destroyed. I even bought a replacement undertray that got destroyed again.
Old May 22, 2013 | 09:19 PM
  #168
GSX 911's Avatar
90% of the Evos ive seen had that plastic undertray missing. Personally I hate that gap in between the bumper and intercooler but Its not a big deal to me.
Old May 22, 2013 | 10:16 PM
  #169
llDemonll's Avatar
huh?
Old May 23, 2013 | 07:04 AM
  #170
wjamyers's Avatar
Originally Posted by llDemonll
huh?
looking down at your bumper from above, you see the ground through the gap between the back of the bumper and the front of the intercooler where the undertray should be. it's the easiest way to tell that it's off.
Old May 23, 2013 | 08:21 AM
  #171
llDemonll's Avatar
ohhh, i get what you're saying
either way i'm keeping mine. takes ~10 minutes to get all the clips off and keep the engine bay clean. for the number of times i actually need the undertray off, having it on is well worth it
Old May 23, 2013 | 08:24 AM
  #172
Hotsauce101's Avatar
I have mine on, and will stay on for the rest of its life. Its my DD and snow here in Minnesota can get bad.
Old May 23, 2013 | 09:15 AM
  #173
GTABurnout's Avatar
I took it off my Evo 9 for routing the brake ducting. Since that car is going back to street duty it will go back on...
Old May 23, 2013 | 09:18 AM
  #174
kyoo's Avatar
ive got the beatrush on instead, just looked under the car and realized i'll have to remove it for fluid changes... sigh
Old May 23, 2013 | 09:22 AM
  #175
littl32an's Avatar
it was cracked, so i decided to just leave it off.
Old May 25, 2013 | 06:58 PM
  #176
GSX 911's Avatar
Most don't have them
Old May 26, 2013 | 10:12 AM
  #177
jameelrose's Avatar
I hated how I could see straight through to the floor through the front bumper grills. It made the front bumper look like a body kit. I drove 100 miles round trip to buy one
Old May 26, 2013 | 10:45 AM
  #178
deziking's Avatar
You don't want dirt/debris build up anywhere near moving parts. I.E a/c compressor clutch or any type of pulley. Especially in snow belt areas. Causes rust and will seize up parts. I learned it hard way on my vw jetta. What happen was under skid plat was removed for over year. One day suddenly no start situation come to find out engine would not turn over due to a/c compressor clutch seized later later found debris/mud/salt stuck in the clutch pulley. Now that vehicle has no compressor.
Old May 27, 2013 | 03:30 PM
  #179
Skyline1215's Avatar
Nice to have but most evos the clips break
Old May 31, 2013 | 07:23 PM
  #180
Evil Racer's Avatar
Yes. I hate it.
