06 MR under 3kmi already needs major engine work.
Old Jan 5, 2006 | 02:20 PM
  #31
Tsurara's Avatar
Originally Posted by dsmfan95
Wait are you calling bull**** that he's running only Mobile 1?
No, he was implying that the reason his engine went bonkers was because he used an oil other than Mobil 1.
Old Jan 5, 2006 | 02:28 PM
  #32
thatsMR2u's Avatar
hmm happened right after u filled up with gas,, make sure u gas cap is tightened down all the way- if it isnt it can throw a check engine light
Old Jan 5, 2006 | 02:37 PM
  #33
Grog's Avatar
Originally Posted by Ev0ikon
It's probably the newer-more-upgraded-more-refined-supper-dupper version of the old P0300 code! :}
keep us posted.
Random Misfire + 1. Hellamisfire.
P0301 actually is related to the P0300. P0300 is for random/multiple cylinder misfire. P0301 is the code for misfire on cylinder number one (similar for P0302, P0303, and P0304 on the other cylinders). According to the service manual, the spark plug and wire are the first things to check when you get this code. They probably just assumed that was the problem and sent you on your way without doing the other checks from the manual (cyl. compression test, injector inspection...).
Sorry to hear about the troubles--hopefully it's nothing too serious. Good thing you can get it repaired under warranty. Good luck.
Old Jan 5, 2006 | 02:44 PM
  #34
onesicklambo's Avatar
i run royal purple always, its fully synthetic.
Old Jan 5, 2006 | 02:46 PM
  #35
feldguy's Avatar
From what I understand is that the 4g63 MUST have cam tolerances within .001 of an inch. The inconsistencies of manufacturing would cause a possible larger runout, causing an exhaust or intake valve not to seat properly. In case of either, poor compression but an exhaust valve would burn out rather quickly under these circumstances. I dont know, though....I figured Id throw in an idea but I have no idea why such a nice new motor would burn up.
Just the same, get a good damned loner and beat the crap out of it. 3k miles on a 36k dollar car brand new......BS!
Old Jan 5, 2006 | 02:53 PM
  #36
Evo VIII 4G63's Avatar
a kid that goes to my college already spun a bearing in his, I think he had something like 1300 miles on it.
Old Jan 5, 2006 | 06:31 PM
  #37
silverlining's Avatar
Other than the mivec, what are the other differences between the new 9 engine version and previous evos?
Old Jan 5, 2006 | 06:42 PM
  #38
zmeli's Avatar
Maybe you just dropped a little keeper (valve spring.) now you do not have compression. let us know.
Old Jan 5, 2006 | 07:28 PM
  #39
Mr. Stock's Avatar
EVERY auto manufacturer has cars that go bad when new. They're machines with thousands of parts. Just be glad it's not a $120K AMG Mercedes or a $55K M3. They've had plenty of issues as well. Heck, even Toyota Camry's have issues. It happens. It does suck when it happens to you though.
If you know anything about Royal Purple, you'll know it's at worst, equal to Mobil 1. If it came down to running either/or in my high $$ engine, I'd run Royal Purple over Mobil 1 without hesitation. Wait, I do run it in my engine!
Old Jan 5, 2006 | 08:12 PM
  #40
alloyic_rs's Avatar
Originally Posted by res04
Cant quite understand why the first thing some people do is swap out the recommended oil????? Its cheap enough in quantity and stock in many high performance cars. My .02 is to stick with it and dont give the dealer an excuse to make life hard for you.
my point exactly
Old Jan 5, 2006 | 08:29 PM
  #41
walkedu's Avatar
with "major engine work" i'd prepare to have your car MIA for longer than "a week or more". More like, months.... I know from experience
Old Jan 6, 2006 | 08:56 AM
  #42
Pineboy104's Avatar
As far as using Royal Purple, some people have already explained why, but it was to rid the engine of any metal shavings that broke off during break in. The dealer did the oil change for me and actually told me royal purple was the best oil i could put in it (which i already knew) so they are not giving me any flack about that. I'm positive i put premium gas in it before i got the code, and the first thing i did when i saw the service engine light was check the gas cap. There was no real change in performance after the light came on also, but me being the cautious person i am, i didnt really push it that hard for fear of damaging anything else. On a lighter note, Pontiac Grand Prix's dont drift very well and cant beat a stock Integra GSR
Old Jan 6, 2006 | 11:23 AM
  #43
res04's Avatar
After 1000 miles I repalced my oil in the IX. Took a magnet to the oil...nothing stuck to it.
If metal shavings occured during break in the scaring on cylinder walls etc. would be insane and we would all have serious oil appetitie issues to boot. Engine parts dont go from machine shop or casting furnace direct into the assembly plant, they will be washed numerous times along the way.
At least thats my experience with the 9 cars I have owned and maintained.
Old Jan 6, 2006 | 11:33 AM
  #44
pretend-evo's Avatar
So... what was the final word on what went wrong with yor car????
y'all complain about reliabilty with a new car?? try driving a 15 year old DSM.. my **** breaks down just looking at it!!
Old Jan 6, 2006 | 11:53 AM
  #45
sleet's Avatar
That sucks bro, good luck fixing it quickly.
