Is my car pulling timing?
Old Jan 6, 2006 | 09:10 PM
Sap12687's Avatar
I just installed buschers race FMIC and LICP, and my car is acting really wierd. On WOT there doesnt seem to be an issue, instead problems occur with mild acceleration. When I slowly let the car spool up it feels like its causing throughout the higher RPMs. Whats causes a car to pull timing?
...FWIW I just got my car pack from the dealer, as they installed a new T-Case, is there any chance they could have reflashed my ECU?
Old Jan 6, 2006 | 09:14 PM
BoostWhore's Avatar
The car may be running leaning causing Knock. Its possible they may have flashed your car.
Old Jan 6, 2006 | 09:15 PM
WHTEVO's Avatar
For anyone to help diagnose your problem you need to elaborate on what the car is doing.
If your ECU detects any knock it will start to pull timing. Many things can cause this so let us know what is exactly happening. Good luck.
Old Jan 6, 2006 | 10:23 PM
Sap12687's Avatar
It feels like im hitting fuel cut but for only a second and then the car heads back up powerband. This happens about 2-3 times a pull. I guess you could call it a really bad stutter. I wish i could explain it a little better so if you have any questions please let me know.
Old Jan 6, 2006 | 10:45 PM
Smoothgangsta's Avatar
1. Was the problem happening before you brought the car to the dealership?
2. Was the problem happening before you added the Race FMIC/pipe?
I was doing an experiment once and I had a Al flash my ECU once with a different Buschur stage flash to see if it would work with what I had and I immediately noticed that my car was stuttering under moderate to WOT when I got into boost.
So I guess what I am getting at is the dealer could have re-flashed your ECU, although I don't understand why they would for a transfer case overhaul unless they knew you didn't have the update P0300 code and decided as a courtesy to do the reflash.
Just a couple of thoughts...
Old Jan 6, 2006 | 10:49 PM
Sap12687's Avatar
The problem was not there with the stock FMIC. Logically,a good way to tell if they flashed it would be to see where rev limiter is, i just havent had a chance to see. The Service engine light is also on at this time because i unplugged the MAF to get to some intercooler piping, could it be that light?
I cannot begin to tell you how frusterated i would be if they refalshed my car...
Old Jan 6, 2006 | 10:55 PM
You need to read the code and reset it with an OBDII scanner right away. Unplugging the MAF midstream like that causes all sorts of issues!
Old Jan 6, 2006 | 10:56 PM
I have done that and it throws the ECU in limp mode, or you can disconnect the negative terminal, step on the brake pedal for 10 seconds to dump any remaining current in the electrical system and then re-connect the neg. terminal on the battery.
Old Jan 6, 2006 | 10:58 PM
Anytime you get a CEL you should immediately read/reset it and determine if it's truly and issue or just a fluke as in this case when you disconnected the MAF.
Your post should have included that information, it would have saved you alot of time.
Old Jan 6, 2006 | 11:22 PM
4WS Tuning's Avatar
Can some1 explain what "pull timing" is....this is a new term for me?
Thanks
Old Jan 6, 2006 | 11:26 PM
electr0's Avatar
The car goes back in time.
Old Jan 6, 2006 | 11:29 PM
4WS Tuning's Avatar
sweet!!!! lol......naa but seriously?
Old Jan 6, 2006 | 11:41 PM
Sap12687's Avatar
The car was doing this before i pulled the MAF and while there were no codes whatsoever.
Old Jan 6, 2006 | 11:53 PM
Matz's Avatar
Thanks
I asked this question recently, because I was only familiar with the terms "advance" and "retard". "pulling timing" == "retarding timing", which means that the ECU will fire the coil later in the combustion cycle.
I am not trying to act like an expert here, but I'll try to explain it as best as I can. As revs get higher, the ECU needs to fire the ignition coils earlier. You want to ignite the air-fuel mixture at the right time, but not prematurely (i.e. when the piston is in the compression part of the cycle... going up). Firing early causes knocking. So if your engine is knocking, the ECU "pulls timing" so that the mixture is ignited at a safer (later) time.
If I am misexplaining anything, please chime in.
To answer someone else's question, if you want to tell if the engine is pulling timing, you'll need to get an OBD2 scanner. I use the Vehicle Interface Adapter from B&B Electronics, but it doesn't come with software -- you have to write your own. The Evo supports the PID for timing.
Old Jan 7, 2006 | 05:59 PM
8urv8's Avatar
I unplugged my MAF to install my new intake pipes, but the CEL didn't come on. The battery was disconnected at the time becuase I was also installing a mini battery.
