It's a Warrtalon Xmas (part 3)
Old Jan 12, 2006 | 08:55 PM
  #91
Warrtalon's Avatar
I'm all in favor of buying parts like that used, though.
3k is a tough limit to set if you include the clutch. For me, it's $925 on performance/tuning and $750 on clutch/flywheel, but my counter stopped a while ago, heh.
Old Jan 12, 2006 | 09:02 PM
  #92
Ultimate CC's Avatar
Yea with these cars you try setting a limit and it just doesn't work, the modding bug is one thats very rough on the bank account
Old Jan 12, 2006 | 09:15 PM
  #93
Boosted AWD's Avatar
How much better will that Forge WG hold Vs. a Stock unit? How much is it?
Old Jan 12, 2006 | 09:24 PM
  #94
Warrtalon's Avatar
It's $170.
They offer several springs with differeing spring rates, but the one that I'm getting is the 19-24psi spring. The stock WGA is 11psi, so our MBCs have to raise boost by 10+ psi in order to get to the desired level. This leads to spikes and taper. I will have mine set at 20psi, so that I basically don't run lower than 20psi, and my Forge UNOS w/soft spring will only have to adjust boost 4-5psi above base on a daily basis. It should spike less, hold boost steady, and not taper much at all.
Old Jan 12, 2006 | 09:26 PM
  #95
BADEVO's Avatar
Wow I guess I dont feel too bad as my Forge WGA was only 150 shipped..........
  #96
eling99's Avatar
where from?
Old Jan 12, 2006 | 09:27 PM
  #97
OHHH lemy know, I may just get one if it controls spikes better.
Old Jan 12, 2006 | 09:32 PM
  #98
EVOONYOASS's Avatar
Looks good War! I see you have the mod bug. I just put on the same 02 housing.
Old Jan 12, 2006 | 09:37 PM
  #99
Warrtalon's Avatar
Well, sorta. I was very happy with where my car was 3 weeks ago, but then Al and the others got the mod bug for MY car, so here we are...
Old Jan 12, 2006 | 09:42 PM
  #100
trinydex's Avatar
Originally Posted by Ultimate CC
the only thing i don't understand is why you are so against a hks rs intake, they are proven over and over to make power when tuned, yea untuned they are source of many problems but when tuned they typically gain 10 to 15 whp, and i don't care who you are but if your getting free parts or discounted i don't think there is anyone out there that wouldn't at least try them, so anyone on his case about that your just not being reasonable, i am real against RNR turbo kits for personal reasons but hell if they sent me a kit for free or discounted i can guarantee as soon as i got it i would be in the shop installin it
wait... i'm running my hks just fine without a tune... stop spreading stuff :P
Old Jan 13, 2006 | 02:36 AM
  #101
Have you hooked up your car to a wideband? I have and it runs dumb lean in spots throughout the rpm range, I couldn't believe it when I first did a pull
Old Jan 13, 2006 | 05:27 AM
  #102
TTP Engineering's Avatar
It's $170.
Half true... Spikes happen WITH the 19-24psi spring as it is hard to control such a fast spooling turbo with a stiff spring. We are starting to change our feeling on the red spring as it makes pump gas boost control without potentially knocking spikes very difficult to impossible to accomplish, you will soon find once you actually test the unit you are speaking of. Anyone running an EBC in combination likely has a very tough time also. The blue spring is about 3psi heavier than stock which is not much. We have shared with Forge, the need for an intermediate spring at 16psi.
Old Jan 13, 2006 | 08:06 AM
  #103
Warrtalon's Avatar
Ok, I will see how it works. That's why I'm testing it out - I want to see how well it works with my setup. So, the blue one is 14-18psi, right? That's not intermediate enough? Were you thinking of a 16-20 or 17-21 type spring?
Old Jan 13, 2006 | 08:12 AM
  #104
I hate this whole "range thing". When you buy a wastegate spring for a tial, you buy a "15psi", it should hold 15. Not 15-19.
If there had to be a range, 15-17 would be it. The blue is 13-14 as tested. The red is 20.5 on my car, however when you spoolup fast and the wga does not start to open until close to 19-20psi, it will overshoot the target until the flapper lets enough boost out.
Old Jan 13, 2006 | 08:14 AM
  #105
Warrtalon's Avatar
I thought there was a range, because you can adjust it? Are you saying that yours is always 20.5, even if it's set to one extreme or the other? And the blue spring won't hold 18 if set to the max?
