It's a Warrtalon Xmas (part 3)
Old Jan 13, 2006 | 08:18 AM
  #106
TTP Engineering's Avatar
I thought there was a range, because you can adjust it? Are you saying that yours is always 20.5, even if it's set to one extreme or the other? And the blue spring won't hold 18 if set to the max?
Those WG spring rates are based on the LOWEST boost you can run if the boost pressure source is routed straight to the WG. Same effect having your mbc set to the lowest setting. My point is that at the lowest setting with the red, it will create spikes to 24 or so.
Old Jan 13, 2006 | 10:09 AM
  #107
honda-guy's Avatar
if you use a 10 psi WG spring, that means if you run the WG with out the vac line connect, the exhaust pressure will naturally open the waste gate at 10psi. you need 10 psi in the exhaust to make 10psi in the intake, in this case a little more because it's not 100% efficiency. so the exhaust psi is always a little higher than the intake side. if you use a boost controller, it uses the boost on the intake side along with the spring to keep the waste gate close. so if you want to run 15 psi with a 10 psi spring, the boost controller allows 5psi from the intake manifold to pass to the WG, so you have a total of 15psi holding the WG closed.
Old Jan 13, 2006 | 11:26 AM
  #108
With the forge, you remove the line with a red spring and it may likely never open at all. Theirs are rated at the lowest you can run WITH the psi on the intake side pushing on the WG baloon.
Old Jan 13, 2006 | 10:38 PM
  #109
BBYBruno's Avatar
Warrtalon, you bought an intake!!! WHAT!!
Old Jan 13, 2006 | 10:47 PM
  #110
Warrtalon's Avatar
Originally Posted by BBYBruno
Warrtalon, you bought an intake!!!!!!!!!!!!! WHAT!!
No, I didn't buy anything.
Old Jan 14, 2006 | 01:43 AM
  #111
BBYBruno's Avatar
Sorry, sponsored intake.
Old Jan 14, 2006 | 06:05 AM
  #112
CFaber's Avatar
soon, he's going to have a fmic too
Old Jan 16, 2006 | 02:46 PM
  #113
gkania's Avatar
Is there a "magic" number you have to hit in order to keep these parts or they are yours free and clear?
Old Jan 16, 2006 | 02:58 PM
  #114
Yes, 6000!
Total Posts: 6,009 (10.24 posts per day)
Find all posts by Warrtalon
Find all threads started by Warrtalon
Old Jan 16, 2006 | 04:23 PM
  #115
Warrtalon's Avatar
Scott got it - I just had to post 6000 times. Now, I'm in the clear...
Old Jan 17, 2006 | 07:58 AM
  #116
gkania's Avatar
Smart@sses, not exactly what I meant!
