It's a Warrtalon Xmas (part 3)
Originally Posted by Mike@Forge
We'll soon be releasing a silicone MAF to Turbo hose to replace the stock piece that creates no driveability issues and can be used with almost any filter kits and upper intercooler pipes that work with the stock intake hose.
I recently PM'd david about the possibility of adding a support bracket to the "ebay" O2 housings as I think the lack of having one is their only negative attribute.
They seem to make good power on virtually any stock turbo or stock-based turbo and they'e cost effective and they seem be reliable, but the lack of a support bracket on the tubular O2 housings is what causes the stainless manifolds to crack when the two parts are used together. The manifold is then supporting the weight of the entire turbo assembly and the front of the exhaust, and consequently cracks under the stress.
If the stainles O2 housing incorporated a support bracket like the OEM housing, it would offer the improved flow while being just as reliable (assuming the stainless used is up to par).
I don't see why the brackets aren't included from the manufacturer, but I think it would be quite simple to create a jig from the OEM housing to weld on a bracket to the tubular units.
Just my opinion!
Just my opinion!
i'm thinking of buying one and welding a support backet to it. I'm going to get my friend to CNC a bracket for me and i'm going to weld it to the flange. this is the only sheet metal 02 housing that i've seen that incorporate the oem support bracket. sorry for the large pics, they are not mine. too bad i sold my megan 02 housing a month ago before i saw the post. now i have to go buy another one.
http://img327.imageshack.us/my.php?i...tuff0084xm.jpg
http://img327.imageshack.us/my.php?i...tuff0091tk.jpg
http://img327.imageshack.us/my.php?i...tuff0105nu.jpg
Well, for those of us just using the stock ported/coated exhaust manifold, that's not an issue, so that's something to think about. Remember that Dave only found gains over the stock ported/coated manifold with the Full Race Manifold, and even then it was only 4whp or so...
http://img327.imageshack.us/my.php?image=carstuff0105nu.jpg
Who makes that?
here's the post, https://www.evolutionm.net/forums/sh...d.php?t=177416
Yah, the SMC alky is already installed and active, but I am waiting for my retune by Al on Sunday before cranking the boost. The cams will be on the way from GSC when they get them in stock on Monday. After that, all I really need is an LICP, which is already in the works.
Originally Posted by Ultimate CC
Sweet, did you do headstuds as well, if you got it open for cams you might as well throw them in, they are a super easy install if you the cams out.
