Grinding..............took to dealership
my friend that works at Mitsu said there's a TSB for the IX regarding a transmission grind. TSB said to replace ring, sleeve and or synchro depending on the type of grind. I get it once in a while and mine in bone stock, noticed it from the first day I drove it off the lot.
i have the same problem. i toke it to them they couldnt reproduce the problem. so i'll just wait. thing being its only in shift to 5th in high rpms. and yes i do get a clunk sound when shifting to third also.
Originally Posted by forbidden color
tsb, they should know about it without even driving it.
anyway, syncros are the only thing that causes grinding, unless you got some funky shifter.
ha and i thought i was the only one who had that 5th gear shifting problem. luckily they fixed my tranny even though they couldnt duplicate it either they just took my word for it. My car isnt even stock either i have tbe with cat delete, boost controller, intake , afc and fmic and piping. They dont even care about my warranty obviously cause i have never put it back to stock
I would highly advise everyone check their tranny fluid LEVEL before taking it to a dealer for grinding. Try to check it in as level location as possible and top it off. The sump on the cars is not huge and running a little low is a little less oil to get into the synchro interface. On my old 2G Eclipse GSX, this normally fixed any light grinds or bumps in shifting. Also, use a quality oil, everyone has a personal favorite, just don't buy the cheapest one.
Also check you SEAT adjustment. Sometimes you think you are depressing the clutch all the way but you really aren't. Click up a notch to where you feel a little cramped and see if the grind goes away. Concentrate on hitting the clutch stop. Sounds odd but I've seen things from this to a floormat between the clutch and clutch stop (
) cause "bad synchros"Just my engineering $0.02
i had the same problem. i took it to the dealership the first time and they changed synchro and gear. the 2nd time i had the problem they try to say it was my driving. went to a different dealership and he was honest, and rode with me. he figured out that the clutch causes the wear on the sychro at high rpm's. they could not fix it because the clutch it not under warranty. BS if you ask me. were working on resolving the problem right now.
