beefier is only good if it doesn't flex as much.
I like hotchkis adj. swaybar.
The hollow inside makes the bar stiffer, unlike the solid inside bars where it allows flex.
Hotchkis will break before it'll bend.
When I gas up and brake, the car leans back and foward.....How can I cure this BODY roll?
Does my Engine need a new suspension?
lol
lol
Quote:
Plus the front sway bar is a ***** to replace.
Well, i have a 27-29mm (solid) adjustable whiteline FSB on my car, its one of the small mods you can do in Astock scca soloII. I really like the bar, it helped turn in and steering feel as well as better front grip. More understeer, hell no, the STi loves a big FSB. I would assume to an extent the evo would too but I dunno for sure, our weigh balances and whatnot are quite similar but again, I dunno. Anyway, dont think that this oversized bars just add understeer, they actually add quite a bit of front end grip, due to them being able to resist lateral loads and let you retain some dynamic camber something that is really valuable when your car is as camber hungry as the STi, granted it would be nice to balance with 24mm RSB but in Astock I cant, otherwise I would and many love that!Originally Posted by Killboy
I've seen a couple, but they're not very popular upgrades. The stock front sway works pretty well, and stiffer front swaybars will make the car understeer more, which it already does pretty well with the 60/40 weight bias to the front.Plus the front sway bar is a ***** to replace.
anyway, just my .02
Quote:
anyway, just my .02
wait a min arent we talking about evo's lolOriginally Posted by AndrewSS
Well, i have a 27-29mm (solid) adjustable whiteline FSB on my car, its one of the small mods you can do in Astock scca soloII. I really like the bar, it helped turn in and steering feel as well as better front grip. More understeer, hell no, the STi loves a big FSB. I would assume to an extent the evo would too but I dunno for sure, our weigh balances and whatnot are quite similar but again, I dunno. Anyway, dont think that this oversized bars just add understeer, they actually add quite a bit of front end grip, due to them being able to resist lateral loads and let you retain some dynamic camber something that is really valuable when your car is as camber hungry as the STi, granted it would be nice to balance with 24mm RSB but in Astock I cant, otherwise I would and many love that!anyway, just my .02
Quote:
This doesn't sounds like any MR I've driven......unless you are really hauling ****.Originally Posted by RobDogg
I'm not as conserned about oversteer as much, I just want to be able to eat a burger while driving, or have it smoother so my girlfriend can use her phone, I try to steer lightly, but, it is impossible to do anything in the car but hang-on and I don't mean from flooring it, just normal lane changes and such
Are you saying that your MR rolls (left-right) soo much you cannot eat a burger?
Well .... the hour is up.... what did you order?
I believe I'm going to go with the perrin adjustable bar.
Quote:
well, I am saying, the sti and evo are both front heavy awd sedans with pretty similar setups, I am just giving some info into this.Originally Posted by mike1023
Quote:
sweet deal thanks hehe titsupOriginally Posted by AndrewSS
Quote:
lol thats a lot of MM. i would say 25mm adj. is good to start with but 28 maybe to much for street.Originally Posted by M5150
I'm personally running a 28mm
I installed bigger rims, Hotchkis springs and the Hotchis sway bar. I love the combo. Body roll is gone. Here's the info from their site:
Hotchkis Tuning Sport Sway bars improve your handling and reduce body roll. Turn in with confidence and late brake in the corners with our track tested lightweight hollow sway bar. During track testing we found that due to the excessive amounts of understeer on the Evo 8, we needed to compensate with a stiffer rear bar. Rear bar includes greasable bushings and brackets.
Rear 15/16" (24 mm) Hollow
3 Position Rear +10%, +27%, +47%
I have mine set on 27%. On a side note, I helped a buddy install the Cusco last weekend and it does not come with brackets. It's also heavier than the stock unit too.
The hours up and I ordered swift MR springs, & RNR turboback+hf cat+magnaflow, being installed this minuteOriginally Posted by Jeff_Jeske
This doesn't sounds like any MR I've driven......unless you are really hauling ****.Are you saying that your MR rolls (left-right) soo much you cannot eat a burger?
http://www.roadraceengineering.com/evoswaybar.htm
this is what i'm running.. and no oversteer problems... can corner like a mad man.. it's awesome... it's got beefier brackets too.. you should check em out... I can't remember but i think this is what's on the mulllerized evo..
