23mm(adjustable) or 25mm r sway bar
Old Jan 25, 2006 | 03:34 PM
  #61
housedj's Avatar
i use the Cusco 25mm adjustable sway bar w/ Perrin rear endlinks & the bar is set to the medium holes (inside are stock, medium is medium, & outside holes creat oversteer). i also run a Cusco rear strut bar & RMR lower subframe brace up front. my car no longer understeers. if the pavement is uneven or real smooth, i can slide the rear out under power.
Old Jan 25, 2006 | 07:25 PM
  #62
Jeff_Jeske's Avatar
Does the lower subframe brace actually provide any benefit?
Old Jan 26, 2006 | 04:46 PM
  #63
housedj's Avatar
yes!!!!!!! the stock 2 front bars actually flex under causing the subframe to twist creating even more understeer. it bolts up in 5 locations & has a depression built in for aftermarket DP's. my '03 is now more neutral handling with the few items i installed. i presume that once i had coilovers, 60 treadwear Advan A032R's, & all the stiffening parts from Nagisa Auto, my car should be able to pull at least 1.05-1.1G's...
Old Jan 27, 2006 | 09:28 AM
  #64
robi's Avatar
But the rmr brace is the weakest of the bunch Works Croxx plate!!! (also helps on the curbing when you are using the inside (AKA dirt apex) line lol
Old Jan 27, 2006 | 10:42 AM
  #65
Jeff_Jeske's Avatar
Well I'm shopping for a rear sway bar now.
I'm trying to decide between Perrin, RRE, and Hotchkis.
I'm not so sure I believe the subframe braces are worth the $$$ at my level of racing.
Old Jan 27, 2006 | 01:20 PM
  #66
robi's Avatar
I'll help Perrin = same as RRE (progress built both) Perrin = more$$$'s hotchkiss is 1mm smaller and hollow too...softest of the 3 choices
Old Jan 27, 2006 | 08:14 PM
  #67
Jeff_Jeske's Avatar
Thank you Robi. Order goes in on Monday. Do I stick with factory endlinks or go with Perrin links?
Old Jan 27, 2006 | 09:37 PM
  #68
robi's Avatar
how loose do you like the car?
Old Jan 28, 2006 | 06:48 AM
  #69
Jeff_Jeske's Avatar
Well....Unlike most people I dont feel the need to be the fastest driver.....I love it when the car starts to oversteer and I can throttle my way out of it. I know sideways is not the fastest way around a turn but to me its much more fun than plowing.
Old Jan 28, 2006 | 10:59 PM
  #70
robi's Avatar
than get the end links and make them as short as possible.
Old Jan 28, 2006 | 11:06 PM
  #71
vboy425's Avatar
any Sway bar is still better than stock, but i would go with 25mm and go with the softest setting, it will still be stiffer anyway
Old Jan 28, 2006 | 11:39 PM
  #72
trinydex's Avatar
you find the most painful ways to take a corner hahaha.
Old Jan 29, 2006 | 09:54 PM
  #73
robi's Avatar
Pain = fast lol!
urbanknight
41
Jan 11, 2014 02:58 PM
shimmi
Mar 2, 2011 08:45 AM
Lightsped
Feb 24, 2011 01:52 PM
varner88
For Sale - Wheels / Tires
Oct 31, 2009 12:31 AM
kos
Dec 28, 2006 04:57 PM
