23mm(adjustable) or 25mm r sway bar
I have a great deal on used 23mm bars (not plural) first thing to com off a customers car who complains about the push...A little bar edu...23full out =22 mm middle = 23mm full in is 24mm.
Originally Posted by Stew
.....and what are the special prices???
https://www.evolutionm.net/forums/sh...d.php?t=178745
Cusco does not make a bracket for the sway bar.
As for the front, you should just keep the stock front unless you are building a full out track car. The labor is very intensive and a larger front sway will create more understeering issue.
Thanks,
Tom
Originally Posted by GTSMWET
Just put her head in your lap
It's a lot harder to keep this car going straight, over my last car
I can't keep my car straight either, but it has more to do with these damn twisty roads around here. Straight=ditch.
Originally Posted by Jeff_Jeske
No alignment needed after sway bar.
It doesn't change any of the static settings, just transfers the action from one side across to the other side during cornering.
are endlinks a must when upgrading the swaybar?
But that's just me, and I could be wrong. --Brad Pitt - Fight Club
hmmm. ok. a rear swaybar sounds like my next mod. has anyone put a rear swaybar on and then upgraded the endlinks? just wondering if anyone has actually felt a difference with them. i'm sure a lot of people have just installed both at the same time.
