IX MR Hating!!
Old Jan 23, 2006 | 12:24 PM
Greg K's Avatar
always have a phillips screwdriver, needlenose pliers, and 8, 10, 12 & 14mm sockets in the car. You can basically take the whole car appart and put it back together with the above.
Old Jan 23, 2006 | 12:26 PM
4TUN8's Avatar
Keep a 17mm and a 24 and you can change all of the Tranny Fluid and the Diffs too.
Rnm's Avatar
Rnm
Yep, learned my lesson after I blew it off the first time. Needless to say, its a good idea to have a set of tools in the car when these inconviences happen. Its happened to me several times already, only because I hadn't tightened it enough.
Old Jan 23, 2006 | 12:28 PM
Greg K's Avatar
a little hairspray on the inside and outside of all of the ic lines works miricles too. Mine popped off 3 times in the first 2 mos I owned the car. Did the hairspray thing, and haven't had one pop off in the last 15 mos.
GgreyEVOIX's Avatar
lol the 12mm socket was a life saver back when I had my sti......chit was always breaking, poping off, or getting loose on that car. I keep a set of tools in my IX now just in case.
Old Jan 23, 2006 | 12:29 PM
AlohaEvo's Avatar
sounds like an IC hose, did you check under the hood yourself before they towed it to Mitsu?
Good luck...
**edit**
Just spray it on? I'll have to give it a try, had one pop off this weekend.
Old Jan 23, 2006 | 12:32 PM
WHTEVO's Avatar
Yup almost guarantee you it blew an i/c hose off. For some reason those tb elbow clamps are too lose. Job security i guess, haha.
Old Jan 23, 2006 | 12:39 PM
Rnm's Avatar
Rnm
Thanks for the tip. Going to do just that.
Old Jan 23, 2006 | 01:08 PM
lil'evil_evo's Avatar
why wouldn't you at least check under the hood just to see if something simple would fix it?
Old Jan 23, 2006 | 01:20 PM
TTP Engineering's Avatar
Boost leak.
Old Jan 23, 2006 | 01:56 PM
zgodfathera's Avatar
sorry guys its cuz im not pro like u guys its was just that..... my cars ready!!!!! yes im not a scrub no more... why havent i seen this before thanks for all the tips hopefully this thread will benefit another newbiE!!!!!
Old Jan 23, 2006 | 03:32 PM
CarbonFibre's Avatar
Must have been the flux capacitor.
Old Jan 23, 2006 | 03:38 PM
Turbolover's Avatar
+1
Originally Posted by ex-honda
You probably blew an IC hose off.
Thats prob. the issue.
Old Jan 23, 2006 | 04:39 PM
mr96gsx408's Avatar
refer to my thread: https://www.evolutionm.net/forums/sh...d.php?t=180541
ugh i hope i have the same case too with my IX... at least the dealer isn't giving you much trouble..
Old Jan 24, 2006 | 08:36 PM
shadow4G63's Avatar
