Removing boost taper
Old Jan 23, 2006 | 12:10 PM
KY's Avatar
KY
I was told by someone that the ECU tapers the boost after a certain amount of time at full boost. I was told to buy a MBC and I will no longer have this problem. I was also told that if I had my ECU flashed I wouldn't need a MBC and my boost would stay at almost 20psi in all gears at full boost. They said the stock ECU tapers the stock boost controller and the addition of an MBC would stop this from happening.
My question is: Is there a way to remove this stock boost controller they are talking about and just run close to 20psi as if I had an ECU reflash?
Thanks in advance
Old Jan 23, 2006 | 12:15 PM
justchil's Avatar
Yes, Several vendors do a "boost controlling" flash.
Old Jan 23, 2006 | 12:26 PM
KY's Avatar
KY
I know about them, but I am trying to see if I can do it without getting a flash right now. I want to wait for my cams and then get flashed. I am just trying to run more boost now without getting a MBC.
andenbre's Avatar
the boost control is part of the ecm so you cant physicaly remove it
Old Jan 23, 2006 | 12:28 PM
4TUN8's Avatar
The only thing I can think of for cheap that would hold you over is building your own bleeder valve.....do a search on home made boost controllers, should cost you about 5 - 10 bucks at home depot and will hold boost better.
Old Jan 23, 2006 | 12:29 PM
housedj's Avatar
the easiest & FREE way to reduce taper is to take your wastegate turnbuckle & turn it all the way down as far as it will go. you will be amazed... takes about 10min to do.
Old Jan 23, 2006 | 12:31 PM
KY's Avatar
KY
All the way down? What will that put me at?
Old Jan 24, 2006 | 09:44 AM
housedj's Avatar
you retain the same boost, you just get to enjoy it longer...
Old Jan 24, 2006 | 11:01 AM
Evolved Monkey's Avatar
Is there a reason why the boost tapers? To put less stress on the engine at high rpms perhaps?
Old Jan 24, 2006 | 11:12 AM
speedracer2169's Avatar
In have a Dejon MBC and my boost still tapers on 1st and 2nd Gear
Old Jan 24, 2006 | 12:28 PM
Warrtalon's Avatar
Please, just get an MBC. You have more expensive, more complicated, and less useful mods, so why are you hesitant to get an MBC? With cams, you will need a tune like you already plan on doing, but it would be a waste to rely on a boost-controlling flash. Just get an $85 Forge UNOS MBC, install it, and happily boost to 21-22psi on a daily basis on 93oct. You will always taper with the stock turbo, but an MBC will limit the taper.
