this could be it!
Old Jan 25, 2006 | 07:00 PM
  #31
Talon's Avatar
If it looks too good to be true, it probably is.
Old Jan 25, 2006 | 07:01 PM
  #32
sne2040's Avatar
Isn't that Greddy Profec-B a boost controller and NOT a turbo timer... If you look at the engine bay, one of the boost lines is blue.
Edit: Yep, it's a Boost Controller... The idiot wrote a Turbo Tuner, which people misinturpered that it was a Turbo Timer...
From what my guess is, it probably has or had a bigger fuel pump, injectors, AEM (or other EMS), Boost Controller, and probably other goodies as well...
Edit 2: Is it just me or is the muffler cracked? There is a thin line at the bottom.
  #33
Talon's Avatar
Originally Posted by SilverNine
beat or not the car looks clean! plus thats what it is set up for anyways....rite??? r u saying the evo cannot take sum abuse?... im pretty sure it can... plus if its been driven hard like its ment to, and it only has that many miles on it, then the buyer has nothing to worry about!!
Grammar, *****! Use it!
Old Jan 25, 2006 | 07:02 PM
  #34
Talon's Avatar
Originally Posted by sne2040
It has a "Laptop cable"...?
Another warning sign.
Engine managmet anyone?
Old Jan 25, 2006 | 07:03 PM
  #35
sne2040's Avatar
**Points to my last post's edit**
Old Jan 25, 2006 | 07:16 PM
  #36
dsm_mikey's Avatar
The car is idling in the pictures. I noticed the boost/vaccum gauge is only at 15hg which seems a bit low for idle. I know mine is right at 19-20 @ idle. Does anyone know what this could point to?
Old Jan 25, 2006 | 08:27 PM
  #37
Warrtalon's Avatar
Mine rests at 15-17.
Old Jan 26, 2006 | 12:20 AM
  #38
Asgeir Logi's Avatar
Thanks a million, i would probably have gone a head and bought this sucker if you hadn´t warned me! though the laptop cable made me wonder... thanks again
Old Jan 26, 2006 | 12:45 AM
  #39
AWDTurbo4's Avatar
Originally Posted by jdmgalant6g72
so the chances of getting a babied evo is probably pretty slim.
like mine
yup, you found one
2 years/4 months 9k miles
Old Jan 26, 2006 | 01:08 AM
  #40
http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
how about this one then?? it has almoust as many miles...
Old Jan 26, 2006 | 03:26 AM
  #41
FinEVO8's Avatar
Looks clean, except that airbox has been cut open. As long as the filter is in place it should cause no harm tho.
Since you are in Iceland are you sure you want US-spec evo? I have no idea of your registeration regulations, but here in Finland it is almost impossible to get US-spec cars registered. You might want to check it before buying.
Old Jan 26, 2006 | 04:03 AM
  #42
what do you mean? in what way is that different?
Old Jan 26, 2006 | 06:45 AM
  #43
FinEVO8's Avatar
I'm not expert in this field but at least older US 8's doesn't have neither ACD nor front LSD. Also there is no rear fog light or tow hooks, lights doesn't have e-approval, rear bumber is different etc. Like I said, I don't know if that is a problem in Iceland but I'd say you definitely should check that.
If you have liberal laws regarding type approval buy Evo 6, It's more fun!
