Radio removle question.
Old Feb 1, 2006 | 08:20 PM
Fusion7's Avatar
I plan on putting my alpine indash in. Now when the stock radio is out is the back open to where I can possible run a wire from the back of the radio to the glove box? Will I need to drill any holes or cut on my car any?
Old Feb 1, 2006 | 08:23 PM
newimportowner's Avatar
no problem. I put my sat reciever behind my glove box and the wires will feed right through. cake.
Old Feb 1, 2006 | 08:26 PM
SterlingEvo's Avatar
once you open it up, you'll see it's wide open. Also, the top back of the glove box doesn't seal up to anything, so you can feed wires right over the top if that's what you have in mind...
Old Feb 1, 2006 | 08:27 PM
Fusion7's Avatar
I have a box about one inch thick and the size of a TV dinner to hide back there think there is nuff room?
Old Feb 1, 2006 | 08:29 PM
Boostd4's Avatar
You might want to consider finding another place for it, there is a lot of room but a TV dinner sized box will probably have to go under the passenger seat...that is unless you don't mind taking up the whole glove box with it.
Old Feb 1, 2006 | 08:30 PM
You will have room on the right side of the back of the glove box. not on the left side. you will see once you open the glove box all the way. I mounted my Sirrius reciever back there directly to the back of the glove box itself, so you dont see it when the glove box is open. but there is not that much room there. 1 inch thick should not be a problem but there isnt that much room on the sides..
Old Feb 1, 2006 | 08:35 PM
Fusion7's Avatar
It doesnt bother my to take up teh whole glove box. I would rather it be in there protected then be under the seat and risk something getting kickd into it.
Old Feb 1, 2006 | 08:36 PM
Fusion7's Avatar
I think my box is about 10x6 I hope it fits.
Old Feb 1, 2006 | 08:40 PM
the one thing i did is i mounted it to the back side of the glove box. i had to remove the ribs ( on what would be the top as your looking at it) so i could mount it to a flat surface. my glove box is wide open inside. its quite cool, when you open the glove box you dont see it. the problem your going to have i think is the size not so much the thickness. take a look, and you might squeeze it in there, but you will see, they didnt leave a hell of a lot of extra room in there for big things. the sirrius reciever is about 4x5x1.5 inches.
much2much
Jan 12, 2024 01:59 PM
Bronko_9695
Aug 1, 2013 09:17 AM
nmilsaps
Apr 2, 2012 05:31 AM
BornSinner
Lancer Troubleshooting
Nov 1, 2007 09:27 AM
Jake26
Jun 6, 2007 12:29 PM
