IX HID not level?
Old Feb 8, 2006 | 11:29 PM
g35sammy's Avatar
IX HID not level?
hey guys i swear that the right headlight is a tad bit higher than the left side.....and it is always like this no matter how low or high i make my headlights. anyone else with a ix have this problem??? also i hear this noise coming from the windshield it seems.....almost as if the windshield is going to crack on me......any help is much appreciated!
Thanks in advance!
Old Feb 8, 2006 | 11:37 PM
SilverShadow03's Avatar
almost all, not all, are like this....my 03 is like that.....I had the dealer align my evodave headlights after reinstallation and it came back same as with stock........my friends 05 is the same as is my dads Audi S4. Don't worry about it.
Windshield creaking? No clue there.......
Old Feb 8, 2006 | 11:44 PM
boost4u's Avatar
my evo9mr has the tapping noise that sounds like it's coming from the windshield sometimes. almost sounds like the wiper blades are rattling against the window. i posted the tsb below.
lookslikeanevo's Avatar
lght output is made that way because street signs and things are on the right hand side of the road, and that left side is lower beacuse you dont want to blind on coming traffic that is on your lefthand side
Old Feb 9, 2006 | 12:21 AM
boost4u's Avatar
for the rattle, found on another thread
TSB-05-42A-005 Released March 2005 (titled: Winshield creaking noise while driving)
1 Test drive to verify noise is coming from A pillar area
2 use a soft trim stick to remove the side windshield moulding from the cowl trim - do not remove the cowl trim for this procedure
3 obtain adhesive-backed thin felt material from BSR kit (MR991752) Cut six felt pieces, approx 70 mm x 5 mm
4 Remove the liner from the back of the felt pieces. Affix the felt on the inner clips. Affix one felt piece to each of the three inner clips Repear on the other side.
5 Be sure that the outer moulding clips (four on each side) are securely attached to the body retension stud. IF the clips are not properly attached, noise may result
6 Reinstall the windshield side moulding
7 test drive to verify the noise is eliminated.
Old Feb 9, 2006 | 01:10 AM
EvoRobert's Avatar
The Evo is not a perfect car. Preformance wise it is pretty close to being perfect, but it will have it's little quirks, squeaks, annoying sounds and such. Just be glad you don't drive a RS.
Old Feb 9, 2006 | 05:39 PM
g35sammy's Avatar
oh the headlight thing makes alot of sense......and yea.....my friend who is a honda mechanic told me it is coming from the drivers pilar area......so that TSB looks like it is right on the dot.....thank you SO much for your help everyone~
Old Mar 7, 2006 | 05:47 PM
g35sammy's Avatar
call me what you want but im not going to try fixing it myself.....hahahahah
anyone have any idea how long it would take the service people and if anyone else has had this problem please chime in! thanks!~
Old Mar 7, 2006 | 09:46 PM
andenbre's Avatar
Thanks in advance!
Benz does the same thing with their headlights and I am sure other manufacturers do it to. they lower the aim slightly on the left light so it doesnt blind oncoming traffic. I am sure that is intentional particularly for HID head lights
Old Mar 7, 2006 | 09:49 PM
andenbre's Avatar
real time... 10 min
dealer time including the slow shuffle of paperwork 1-2 hrs
Old Mar 8, 2006 | 12:16 AM
Evo_Jay's Avatar
I had the problem with the windshield creckin in the VIII and think I might have it in the IX.
With the VIII, Mitsu released a TSB, so I got it done and the rattle went away.
They forgot to put this felt between the window and plastic that holds it.
Don't know why they would forget again.
The job only took 20-30 mins at the dealer.
The only problem is there is no TSB yet. Last time when there was a TSB, I had a hard time convincing my local dealer that there was one. I had to drive there 3 times (hour away-60 miles) even though the first time I called them I gave them the TSB number and told them I'd like to make 1 trip.
Old Mar 8, 2006 | 07:23 AM
g35sammy's Avatar
it is that hard to get it fixed huh? damn......dealerships suk major a$$. those directions seem a little confusing. anyone that has fixed this minor issue have any tips or can explain a little better exactly what to do please help me out!!~ thank you ^.^
Old Mar 8, 2006 | 07:26 AM
forbidden color's Avatar
your left side is lower, because you don't want to blind the oncoming traffic.
left side is always lower, since we don't have a self adjusting hid housing like bmw, benz, audi.. list goes on and on.
My right one is always been higher than the left.
Old Mar 8, 2006 | 07:37 AM
byron3636's Avatar
WOW... I thought I was the only one with the annoying uneven lights... awesome that it's actually built that way and I just didn't notice it right away.
Old Mar 8, 2006 | 09:16 AM
mbamrah's Avatar
My evo IX is about 2 months old, and I am getting the noise from the windshield. Was going to ask the dealer to look at it during my first service. Evo kid where did you get information on the TSB? Does anyone know if there is one out for the IX?
