EVO broke, dealer clueless.
Old Feb 15, 2006 | 02:50 PM
prostcj's Avatar
I was on the highway about a week ago and when I got on the gas to pass a vehicle I heard a loud pop followed by a loss of boost. The car started running real rich and I had to get a tow to the dealership.
I imagine most of you are probably saying it's obviously an air or fuel problem. Well get this, the dealership has had it for over a week and they still don't know what is wrong with the car.
Supposedly they have some sensor on the way that might help them diagnose the problem.
Any one heard of a dealership taking this long just to figure out what is wrong with the car?
Old Feb 15, 2006 | 02:52 PM
Rnm's Avatar
Rnm
Did you bother checking under the hood to see if one of your clamps got loose? I've had that happen before and it felt like I hit a brick wall and lost all power. I pulled over and found the clamp on my throttle body came loose, put it back and I was back on the road.
Old Feb 15, 2006 | 02:53 PM
GTSMWET's Avatar
Was it running rich, or wasn't it staying started. Sounds like an intercooler piping blew off, but you would think a dealer could find that. Hmmmm i would even check the lower I/C Piping
evilevovegas's Avatar
It sounds like you ic hose just blew off. You might have them check. Sounds stupid but maybe they overlooked the most simple probability and thought to hard about it.
Old Feb 15, 2006 | 02:55 PM
urBan_dK's Avatar
Hmmm....leak down test? Anyone?
prostcj's Avatar
I agree with you all and the dealership checked these things last week. They even put the stock BOV back on thinking it was a failure of my Forge BOV.
Old Feb 15, 2006 | 03:01 PM
Ekasey's Avatar
hmm interesting problem your having kind of scary the delaer hasnt figured it out yet i'd suspect a looose ic pipe first
Old Feb 15, 2006 | 03:06 PM
drharlequin's Avatar
you probably should have removed the BOV, now the dealership will probably blame that for what happened. too bad.
Old Feb 15, 2006 | 03:10 PM
zgodfathera's Avatar
^ ^yeah thats what happened to me.... how would u know if its running rich?
prostcj's Avatar
I'm a little scared. On the bright side, it probably isn't anything major like the turbo itself. I'm afraid I have too many aftermarket parts on the car to have removed them all before taking the car to the dealer.
I hind sight, if I knew they would have the car this long, I could of spent a weekend converting the car to stock.
Old Feb 15, 2006 | 03:14 PM
housedj's Avatar
did they bother to check all the I/C hoses? even the elbows on the I/C itself?
remember all "techs" are technically clueless or they wouldn't be techs, they would be master mechanics...
Old Feb 15, 2006 | 03:15 PM
prostcj's Avatar
It spits unburnt black sludge out the pipe when the revs go over 3k (again it seems like an obvious air issue).
Old Feb 15, 2006 | 03:16 PM
kmcconn9's Avatar
/\ that was exactly what I was thinking..
Old Feb 15, 2006 | 03:17 PM
prostcj's Avatar
Their original estimate was that it was the BOV or IC hose. I'm assuming they would of checked every hose by now but you know what happens when you assume.
Old Feb 15, 2006 | 03:18 PM
prostcj's Avatar
By hose I meant pipe.
