DSM 4G63 vs. Evo 4G63
Old Apr 29, 2012 | 11:53 AM
  #31
barneyb's Avatar
Originally Posted by cursedsm
All motors can crank walk. I know of a bunch of them that " supposedly crankwalked had to do a lot with people were retards and don't do things right and the flywheel and clutch were not installed correctly causing the crank eat at the sides, along with the improper tq specs on the main caps. Majority of the "supposed" crank walks are problems with cluch not being installed correctly. Crankwalk was a product of the early 2g using a different 2 piece bearing and the motor not being properly oiled due to ****ty design.
I'm not sure what you mean by "supposed" crank walk. To me, crank walk is crank walk. I was active on the DSMtalk forum when all this was happening. Even owners with automatic transmissions were experiencing crank walk. When an owner experienced crank walk the only thing to do was junk the engine. This was because nobody knew how to fix a crank walked block. People tried but the result was that they crank walked again. Six bolt swaps were all the rage.
About the time that Mitsubishi was ending production of the second generation DSM, Mitsubishi announced they had an engine available that had the crank walk problem addressed. I remember an owner purchasing and installing one of these engines but I never heard how it did.
Old Apr 29, 2012 | 12:04 PM
  #32
Mrauto50's Avatar
I had 4 Eclipse 4g63 Gst & GSX. The last was built. I had around 12k in it. Yes its every bit as fast, but leaks and break downs were very common. I beat in my built Evo and don't think about it. The 90-94 motors were the best so if you were like me, and loved the 2g (95-99) you had a world of work a head of you. Cheaper to just get a Evo...lol.
Old Apr 29, 2012 | 12:14 PM
  #33
CurseDSM's Avatar
Originally Posted by kyoo
sad but true.. becoming the new dsm (no offense)
Yeah isn't that sad. I read what some people do to there cars and I just shake my head.
Old Apr 29, 2012 | 12:16 PM
  #34
CurseDSM's Avatar
About the time the Mitsubishi was ending production of the second generation DSM, Mitsubishi announced they had an engine available that had the crank walk problem addressed. I remember an owner purchasing and installing one of these engines but I never heard how it did.
I use the term supposed being anythign that goes wrong with the motors most dsmers say its crankwalk. Its just an excuse when they actually don't know wtf the problem is. I mean alot of what it was was an oiling issue. The bearings werent getting enough oil and when that happens **** breaks. I have seen so many people try to describe crankwalk and you ask them does your crank have any side to side in it? "well no" then your an idiot its not crank walk its something else. It just pisses me off that everyone jumps on that bandwagon. Whats even funnier is Chrystler used that same bearing on alot of the different 2 liter cars they had with no issue. Even the csx-vtn had the same style of bearings and them things were tanks. I mean I don't want to argue with anyone about it but your right if its crank walk its crankwalk but im just so tired of hearing its crank walk when its in fact not.
Old Apr 29, 2012 | 01:07 PM
  #35
beautifulpunk's Avatar
DSM's: fast and unreliable!!!!
Old Apr 29, 2012 | 01:28 PM
  #36
CurseDSM's Avatar
Depends, fast yes I agree, unreliable I don't agree with. The car was never ment to be what they are today. If you build one properly and take every measure to make sure they will last you a long time they are very reliable. What people do not do is get one replace everything that has importance and just beat the **** out of them and they break. Remember they are anywhere from 22 years to 14 years old. So people who buy them even 10 years ago still didn't replace things that should be replaced and they break.
Old Apr 29, 2012 | 01:31 PM
  #37
reactionevo8's Avatar
interesting read,although there seems to be some misinformation regarding evo thrust washers...03-06 evo blocks use 2 180 degree thrust washers on opposite sides of the main that aren't integrated into the main bearings...
Originally Posted by sonicnofadz
7 bolt EVO (2003-2006+): 360 degree thrust bearing (hence the low occurence of crankwalk, again just a popular theory).
Old Apr 29, 2012 | 03:41 PM
  #38
Runker's Avatar
I had a 6 bolt swap GSX a few years back and I agree with you completely!
Old Apr 29, 2012 | 03:43 PM
  #39
nightwalker's Avatar
You guys want to talk DSM, the new 4B11 is a true DSM, without the DSM name attached.
Old Apr 29, 2012 | 05:11 PM
  #40
barneyb's Avatar
As I already wrote, DSMs were responsible for creating a generation of great mechanics. There was always something on the car that needed attention. And, the car appealed to young people, people who had tons of energy.
I remember a guy who was having trouble with his clutch. He pulled the transmission five times before he finally figured out that a piece of the clutch lining had come off and was wedged between the disc and pressure plate. But the best story is as follows:
There was a thread started on DSMtalk by a person who wanted to convert his normally aspirated car to a turbo. This was a common question and the normal advice given was to trade the car for a turbo. Doing a conversion just about required a donor car because everything was different and had to be swapped, starting with the engine.
With that advice given some fellow chimed in saying the job wasn't that difficult. He and his buddy, he wrote, owned several DSMs and they wanted to sell one. This was a normally aspirated car and they decided it would sell better if it was a turbo. So, they did the conversion.
Only one person responded to their ad., a father looking for a car for his daughter. The prospective buyer wasn't too hot on the idea of his daughter driving a turbocharged car so they swapped back to normally aspirated.
Old Apr 29, 2012 | 09:48 PM
  #41
CJ2X's Avatar
Great read. People always ask what the differences are, and I never knew there were too many differences, only mivec for IX's.
Old May 2, 2012 | 12:31 PM
  #42
GPTourer's Avatar
The thing is, any time a DSM breaks down, for any reason - somebody says "uh oh, CW." And there you go, the legend continues.
I drive my '98 GS-T more so then I do my Evo, and even though it now has a six bolt bottom, the car does well and holds up and doesn't have any issues. Other then the fact that it is not a 14 year old car and some things are wearing out - like I just did a rear wheel bearing last month. Other then that - no issues. I do think my Evo is put together better, but I don't blame that on Chyrsler or UAW autoworkers in Normal. It has a Japanese built engine and transmission and that's all that really matters IMO. Now that I don't race it or beat on it every time I get in it like I did years ago, the car has never even hiccuped.
spoolin98
Jan 2, 2017 08:33 AM
4G63 DSM
Mar 19, 2016 06:32 AM
PHILLY EVO
Jul 7, 2015 07:29 AM
maperformance
Jun 25, 2014 09:44 AM
GTVEVO
Dec 1, 2007 11:39 AM
