HKS BOV poped off!!
Old Feb 19, 2006 | 05:17 PM
Z-Ball's Avatar
HKS BOV poped off!!
I posted in the install section but theres like no one in there so i posted here too.
I just got the hks blow off valve with the extra pipe and installed it my self. i couldnt mount the blow off valve on flange tho cuz that c clip was givin me some trouble.. so i took it back to the place i bought it and just had them mount the bov on the pipe. i took it home put it on the car and connected the bov hose back to teh blow off valve... i was done installing it... i started the car, then gave the car a couple of revs.. it sounded great and in working order... i took it out and drove it carefully. after about 5 minutes of that i tried to go a little faster and i gave it some gas in second, shifted to third and POP!!! i and i hear a clinging on the street. my BOV poped off the pipe!!! and i lost the O ring... any advice on what i should do now??
Old Feb 19, 2006 | 05:25 PM
PapitoEVO8's Avatar
Yes, I remember when I had the HKS BOV. The flange was motherFu__cker to put on, but I got it on and it worked perfectly until I sold it. But in my opinion on the HKS: I did not have the mods and still don't to get the best out of this BOV. I used a pair of needle nose pliers and some hard *** elbow grease to get it on LOL. You can buy another adapter for it on ebay.
Old Feb 19, 2006 | 05:29 PM
Z-Ball's Avatar
what do u think caused it to pop off? maybe i need a better c clip?? or what im buffuddled on how it could pop off like that, im guessing it wasnt on the flange tight enoght
Old Feb 19, 2006 | 05:33 PM
PapitoEVO8's Avatar
It was put on wrong. I know is very hard to put on. But do it yourself it the best guarantee it will work
Old Feb 19, 2006 | 05:38 PM
andross85's Avatar
mine pop off once before i screw it with a electric tool...
Old Feb 20, 2006 | 02:31 PM
hondafan's Avatar
go to sears and buy a pair of snap ring pliers for $15 and return them when you're done. they work wonders on the clip. they have little protrusions that go through the tiny holes on the snap ring and can close the ring till the ends are touching no problem. anytime you work on your car, you'd be suprised the difference in time and effort when you have the proper tools.
Old Feb 20, 2006 | 02:34 PM
Technical XTC's Avatar
When I ran a HKSSQBOV on my DSM, I welded it on there, NEVER had an issue, ever.
Old Feb 21, 2006 | 06:58 PM
Z-Ball's Avatar
did i not install it right or is the c clip just not strong enough? cuz i am thinking of just welding the thing on.
Old Feb 21, 2006 | 07:00 PM
Z-Ball's Avatar
maybe the place put the c clip upsidown
Old Feb 21, 2006 | 07:01 PM
staatz's Avatar
If it was installed right it wouldn't have popped off like that. Trial and error. Might as well try it again and make sure its on there tight!
Old Feb 21, 2006 | 07:04 PM
Z-Ball's Avatar
man it was scary when i heard that POP!!!!
Old Feb 21, 2006 | 07:06 PM
bigyellowevo's Avatar
Just make sure the c-clip is secure and it will be fine.
Old Feb 21, 2006 | 07:17 PM
Evoryder's Avatar
what the hell is a "c clip" ...a friend has a hks on his evo...all that were used were regular clamps...
...if in doubt...Tbolt clamp it out.
Old Feb 22, 2006 | 03:32 PM
Z-Ball's Avatar
K its like a day later and i want to ask any one know if i can weld it on the aluminum pipe or will aluminum not weld with the blowoff valve
Kevin Knight
Nov 26, 2016 08:56 PM
initialdrew
20
Nov 6, 2012 04:58 PM
steelersgame
Sep 15, 2012 11:11 AM
Kevin Knight
May 4, 2007 11:19 AM
