Power Windows
Old Feb 22, 2006 | 03:54 PM
Evo_Bill's Avatar
Power Windows
I'm going to be converting my RS hand crank windows to power (parts from smacked up evo)
Anyone ever done this with any car before? I have all the parts and tools.
My main concern is the wiring harness.
-Does the RS come with the same Harness?
-How do I deal with wiring these up?
that's all I have for now but I'm sure I'll have more as I go on.
Old Feb 22, 2006 | 04:49 PM
Evo_Bill's Avatar
bump
Yo anyone with service manuals that could "hook" me up with some PDF's on this topic?
Old Feb 22, 2006 | 06:05 PM
gabesir's Avatar
dood i think i was the first one to do it and the wiring its always the worst.. but on the other had i have done two other car from no power to power door..
i have everything working right
to your question about "prewired" no the car isnt for power doors. so if you look closely there isnt no wires "pigtail" going to the back door so you will have to drill a hole to pass the pig tail for both back doors..
but have fun!
Old Feb 22, 2006 | 06:08 PM
gabesir's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=116897
he did it also!
Old Feb 22, 2006 | 08:18 PM
Evo_Bill's Avatar
basically when I get the stuff when I connect the wiring from the door to the Main harness underneath the driver side, that should be it for wiring
Hoping. that keep all the wiring for the doors and everything else wired to that harness.....
Is that all you did? as far as wiring goes?
Old Feb 22, 2006 | 09:06 PM
DSMorBUST's Avatar
--or you can just do the front doors and leave the back ones manual.. but that might be downgrading a lil bit to srt4 standards..
Old Feb 23, 2006 | 06:23 AM
Evo_Bill's Avatar
I understand I'll have to add a "pigtail" and spilce in the wire for the back doors in to the fronts but I'm asking when I plug in the fronts in to that harness underneath drivers side its that all to get them working?
Old Feb 23, 2006 | 06:47 AM
gabesir's Avatar
no.... some of the wires worked.. like to power the external relay that i use to make the windowns go up and down... but you still have to run wires from the driver side door to all the remaining doors... remember you have the master switch on the driver side that controls all the other doors.. so wires have to be ran like a ****! good luck!
Old Feb 23, 2006 | 06:52 AM
WrX Kila's Avatar
Should not be that difficult.
Old Feb 23, 2006 | 07:25 AM
tke_413's Avatar
YOU ARE WRONG...SORRY!
You do NOT have to run wires to all the remaining doors if you get the correct parts to start with. Get OEM parts from another EVO. The wiring harnesses replace the ones already in the door and plug into all the replaced parts. To get the power locks working, you must get the new red lock "brain" that is behind your steering wheel (you can see it by looking up from the floorboard). Here's the parts to buy off someone...
Door panels
Window regulators
Window motors
Wiring harnesses
Red lock "brain"
Lock assemblies (handle with 2 bars going to the lock actuator)
Then all you do is replace all the parts, plug the new harnesses in behind the kickplate and BAM...you have both FRONT doors working. The rears are a little tricky, you'll have to drill holes for the wiring to enter the car and THEN splice the wires into the front doors. Hope this helps, otherwise PM or IM me and I'll be more than happy to help you out.
Old Feb 23, 2006 | 07:53 PM
Evo_Bill's Avatar
need some pics of Locking Assemblies and "red lock"
these would help thanks
Old Feb 24, 2006 | 08:08 AM
Evo_Bill's Avatar
bump.
Old Feb 26, 2006 | 02:10 PM
jester7500's Avatar
Did you start the conversion yet Evo_Bill? I'm interested to see how it goes.
Also, where'd you get the parts you already have from? From a wrecked Evo? If so, how much did you pay? Thanks.
Old Jun 18, 2006 | 08:49 PM
Evo_Bill's Avatar
ah ****...
power door conversion on the way.
Old Jun 19, 2006 | 06:20 PM
djevoawhp's Avatar
thats cool...i didnt know it was that easy
