Launch Control
Old Feb 23, 2006 | 09:29 AM
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
Launch Control
I had a quick question ... someone told me that the EVO has a built in launch control (2step) is this true? Sorry for sounding like a newbie on this but I'm not down to try it out unless I know for sure its true.
If it dosnt ... is there anyone that makes a 2 step control unit for the evo?
Old Feb 23, 2006 | 09:34 AM
Doogie Howser's Avatar
5K rev limiter.
Come to a complete stop. Select first gear and then hold down the gas and your car won't go past 5k rpms. 5k may be a bit low to launch but you never know...
Old Feb 23, 2006 | 09:46 AM
M3this's Avatar
Thatxs what I was told .... I was also told it builds boost at the 5K
Old Feb 23, 2006 | 09:52 AM
bigfishs's Avatar
Warr has it on his car. Dynoflash can do it for u I believe.
Old Feb 23, 2006 | 09:56 AM
M3this's Avatar
Whats this difference over stock? They raise the RPM limit? Anything else?
Old Feb 23, 2006 | 09:58 AM
Nez136's Avatar
i believe they raise it to 5.5k, or you can request a limit(i think) I would go 6k!
Old Feb 23, 2006 | 10:11 AM
Warrtalon's Avatar
Yes, all 05s and 06s have this built-in 5k launch limiter that inadvertently behaves like a 2-step launch control. Yes, it also builds boost (~5-7psi).
Also, you can get launch control with a Dynoflash, and you can have the RPM set wherever you want. The default RPM is 6k rpm, which is where mine is set in this video:
Dynoflash 2-step launch control (6k rpm)
It was discussed in this thread:
As requested, here's a vid of my 2-step Dynoflash launch control
With the 6k limiter, it builds 10-12psi, but I would not recommend using it too often with a cat, though.
Old Feb 23, 2006 | 10:16 AM
gaijin's Avatar
If you want to roll to Phoenix, Jay @ Mynes can adjust it for you too. Did wonders for Maxx's car. 1.6 60' with ats clutch and stock everything else.
Old Feb 23, 2006 | 10:18 AM
M3this's Avatar
Warrtalon thanks for the info ... I'll check out that thread you posted!
Old Feb 23, 2006 | 11:07 AM
4g63IXMR's Avatar
nice info
Old Feb 23, 2006 | 07:42 PM
RnR Racing's Avatar
5K is stock. If you need it higher get it flashed.
Old Feb 23, 2006 | 07:43 PM
Warrtalon's Avatar
Um, yeah, I think we got that covered. Read above.
Old Feb 23, 2006 | 08:09 PM
DSM GSR04's Avatar
wait ive revved my 04 to 6k and launched before?? and yes i was at a complete stop, i know that some people say that if ur not at a full stop u can do this but i was completly stopped and able to rev it to 6k and now that i think maybe even 6.5k
Old Feb 23, 2006 | 08:12 PM
Warrtalon's Avatar
Ok, monkey, read closely:
Old Feb 23, 2006 | 08:13 PM
TTP Engineering's Avatar
Um you have a 2004. They are talking about a limiter for 2005-2006.
