Clean out grease from engine
Old Feb 23, 2006 | 03:51 PM
2vonku's Avatar
Hey guy, what do you guy use to clean your engine. I mean like getting all the grease out and everything else that is building up on it. I was thinking about getting some engine degreaser and throw it on there and wash it up. Is this recomended. What do I have to cover up inside engine compartment so water do get on it when I hose it off. Thanks. Any advice will be appreciated.
Old Feb 23, 2006 | 04:27 PM
skiracer's Avatar
I use brake cleaner. Regular degreaser you have to rinse off with water. whereas brake cleaner evaporates quickly when you wipe it with a towel....
Old Feb 23, 2006 | 04:30 PM
DDDEVO's Avatar
Gunk Citrus Engine Brite. Spray it on, let sit for 15-20 mins and rinse off with water...and voila!!!!!!! Can has a dual stage spray tip, lets you get in those tight areas really nice. I think I bought mine from Auto Zone, but most auto stores should carry it. Good luck to you, and remember to cover up any electrical accessories!!!
Old Feb 23, 2006 | 04:36 PM
xme's Avatar
xme
when you spray in the engine bay .. what are some of the stuff that is needed to be covered ?
Old Feb 23, 2006 | 04:40 PM
urBan_dK's Avatar
Plastics if you are using engine degreaser
Old Feb 23, 2006 | 05:03 PM
Ultimate CC's Avatar
I use some armorol engine bay cleaner, just cover up your intake and don't spray any of the electrical stuff directly, afterwards wipe the engine back with a rag.
Old Feb 23, 2006 | 05:12 PM
MrFairlady's Avatar
cleaning the ol' Type-R was easy.
Open hood...spray w/ simple Green Engine Cleaner (blk bottle) -covering Battery,Dist,and intake cone if you have one.
Spray all on engine valve cover etc.Crank car w/ hood closed and let run for 5-10 mins while it burns everything off and Steam Cleans everything....then turn car off...open hood and Spray w/ High pressure Hose @ car wash.
Done and its Perfectly clean!
I'm not sue about the EVo though...far to much stuff going on then a Honda/Acura engine bay.
Old Feb 23, 2006 | 05:18 PM
mdesi's Avatar
Simple green. IMO its the best stuff you can use for your eng. It cleans everything without fadding or discoloring. And it smells good.
Old Feb 23, 2006 | 05:25 PM
gsrboi80's Avatar
I used to use Black Magic Engine Shine on my Integra GSR
Old Feb 23, 2006 | 06:02 PM
nnorris7413's Avatar
What kind of electrical stuff do you have to cover up?
Old Feb 23, 2006 | 07:32 PM
binarysleep's Avatar
Bump for Simple Green. Don't leave it on too long or it might discolor plastics/metal. Cover anything electrical, and everything associated with your ignition (plugs/wires/etc). It's safest to:
A. Wash only a cold engine. Spraying cold water on a hot engine is a recipe for cracks.
B. Hose the engine with a stream, not a spray (direct the water only where you want it).
if your car won't start after you wash it... just wait.
Old Feb 25, 2006 | 08:58 AM
evorace's Avatar
mainly watch out for the maf meter. If it gets wet, the car will stumbled and idle wierd until it dries out.
Old Feb 25, 2006 | 09:43 AM
Stangar's Avatar
NO!!!! Use brake cleaner only on metal and preferably non painted metal. It's a degreaser and is extremely detrimental to rubber parts.
Recks_EVOX
Oct 17, 2014 08:09 AM
ihatemyusername
Jun 25, 2014 03:50 PM
Boost3dxEvO
Jul 9, 2009 07:02 PM
ashun22panda
13
Mar 4, 2008 02:15 PM
evo959
Nov 20, 2005 03:48 PM
