DEFI BF Illum Issue.
Old Feb 23, 2006 | 04:49 PM
MrFairlady's Avatar
I hooked up my DEFI's and these were out of my STi and using the How-To for illum was using the Cig lighter - but that means the gauges were only coming on when the headlights were turned 1 click.
SO I re-hook them up using the Power wire and they are on ok now...but the DIm function dosen't work on the gauges.You can press the up/down arrow and they will dim or Brighten but that dosen't work anymore for some reason.
I hooked the white wire (defi Illum) to the Red wire (ign on) on the Cig assy.
any clue why they won't dim but work like normal even w/ memory?
Old Feb 23, 2006 | 06:33 PM
Evasive EVO's Avatar
Perhaps because you're hooked up to a constant 12v source for your illumination? I just installed my BF's this past weekend and I tapped into the radio switched 12V for the illumination and my dimming feature works perfectly. Infact, I tapped everything off the radio harness since none of the darn how-to's showed how it works on an EVO IX and the cig lighter area. The wiring was all different for me down there. Let me know if you need help, I could give you the pinouts if you need.
Ed @ Evasive
Old Feb 23, 2006 | 06:44 PM
MrFairlady's Avatar
thats whats weird.
I taped into the Correct wire that the how to told me to but the gauge worked but wouldn't light the face only the Flashing Red light would work untill I turned the Headlight switch once.And even w/ the Headlight/gauges face on..it still woudn't dim.
I tried the 12v because I thought thats what I used for the STi (clock) but the DIm feature still won't work.
I don't understand the whole "Pinout Thing".I guess its just hardwiring to the ECU?Not sure how that works.just know the ol' fashioned way.
I'm installing a new CD player in a week or so.I guess I tap into that Illum wir once I do that.Maybe thats what I need to do to fix it.
Old Feb 23, 2006 | 07:33 PM
heron163's Avatar
Ed @ Evasive
Ed - I am having sthe same problem - which wires on the IX radio harness did you tap into?
Old Feb 23, 2006 | 07:53 PM
Jeller's Avatar
make sure its also plugged into the correct spot on the control panel, there are 2 spots,
and here you go: https://www.evolutionm.net/features/...rojectevo/24/3
Defi Wire Stock Wire
Constant Power (Red) »Black w/ Red Stripe on Radio Harness
Ground (Black) » Black Wire from Cigarette Lighter
Ignition On (Orange)> Red Wire from Cigarette Lighter
Illumination (White) »Green w/ White Stripe Wire from Cigarette Lighter
Old Feb 23, 2006 | 08:21 PM
MrFairlady's Avatar
Thats what I used..and they got some wires wrong.
The Brown wire on the Cig assy is the "Red" wire.There is no Red wire there.
When I hooked it to the Green w/ white Stripe (cig assy) w/ Defi White wire (illum wire)...thats how I got the gagues working but wouldn't light up untill I flipped the headlighst up 1.
Reason for that and its gotta be wrong is becasue the Cig lighter is not always lit up...It has the light for when its dark and you obviously have your lights on.
Old Feb 23, 2006 | 08:25 PM
essjEVO's Avatar
happened to me, but i check where i hooked the meter wire onto the back of the controller...
check to see if you plug the meter wire onto the meter 1... its suppose to be on meter 2
Old Feb 23, 2006 | 08:30 PM
MrFairlady's Avatar
I think it only fits in 1 certain one.thats whats weird,but I'll def check again...That may be right.I know theres 2 but one I think is bigger than the other only allowing the size I've got.
thanks though I'll check.
Old Feb 24, 2006 | 12:34 PM
heron163's Avatar
it would be nice if someone had definitive instructions on wiring this up
Old Feb 24, 2006 | 01:28 PM
MrFairlady's Avatar
Checked and I do have it hooked up to the meter 1.But when I plugged it in,the Oil pressure did not light up but BOOST.But I know the gauges are weird...you have to restart the car and everything in order for them to read right.
gotta try it again now that I know for Sure that its Meter 2
Old Feb 24, 2006 | 02:06 PM
AMSTuning.com's Avatar
Wierd sorta similar problem on my Evo.
Defi's worked like a champ for months. Car has been down due to some stuff being added...and the battery was low on voltage. So we hooked up a jumper box to give it some extra voltage. After getting everything squared away, fired up the car, and the gauges only lit when the lights were on. Checked all the wiring, all was proper.
The gauge still worked, and the warning lights worked as well, but no illumination...gauge was black. So I hooked up the illumination wire to the switched power, and now the gauges work fine. Don't dim with the headlight, but who cares.....
Same thing with a customer car. Gauges work fine, but no illumination. Turn the lights on, and they light right up.
I think the battery jumping thing killed something inside the brain.
Old Feb 24, 2006 | 02:23 PM
MrFairlady's Avatar
I don't think they dim w/ the headlights unless you maybe hook it to the Illum of the radio harness...but On my STi I had them hooked up Correctly and they stayed 1 shade untill you dim them yourself w/ the control unit.
Not sure if that was a feature on them but thats why It has the dimming feature.
Old Feb 24, 2006 | 02:29 PM
AlohaEvo's Avatar
They dim when you turn on the headlights, at least mine do. I hooked up the defi illum wire to the light on the cig lighter ring.
Old Feb 24, 2006 | 06:09 PM
onesicklambo's Avatar
if ur just running the bf gauges you need to go out of METER 2 on the link. might be your problem?
Old Feb 24, 2006 | 06:17 PM
MrFairlady's Avatar
Yeah I did it when I left work and that was it.I haven't used em in so long I couldn't remember what slot.
DIm feature works but since I still have it hooked up to the Constant 12v the Illum doesn't dim whne I turn Heads on...but oh well.Everything works great.
PauloPinho
Oct 11, 2016 01:37 PM
2rbolag
Sep 23, 2016 08:43 AM
outsider
Southeast Region
75
Jul 30, 2005 02:02 AM
aresix6
May 8, 2005 03:27 PM
rvamikey
10
Mar 14, 2004 06:29 PM
