Dual map and ecuflash
Old Sep 29, 2016 | 03:55 AM
PauloPinho's Avatar
EvoScan Knock Sun
Hi everyone
After remap my car by a pro wich use ecutek i read my ECU with ecuflash and i saw that he dosen't disable a few things
so if i disable this things and remap the car with ecuflash i will steel have my dual map?
thank's
Old Oct 1, 2016 | 08:19 PM
Raceghost's Avatar
List "things" please?
Old Oct 1, 2016 | 11:19 PM
PauloPinho's Avatar
Hi
disable EGR. I removed the EGR and he juste disable the error codes
Old Oct 5, 2016 | 11:07 AM
PauloPinho's Avatar
with TephraMod V7 i found all maps and the differences between both are pretty cool
if i use this method i disable the egr in both maps?
In the ECU:
-XXX- See Mr Fred Quote Below, might be good anyway- Change Periphery 0 (FAA) bit 11 to 1 (to disable EGR Timing advance)
-XXX- Not necessary if disabled correctly - Change Periphery 2 (FCA) bit 09 to 0 (to disable P0401 EGR Test)
-XXX- Unrelated, but a good change for anyone with problems - Change periphery 4 (FEA) bit 14 to 1 (to disable MAP vs Baro test on startup - not necessary but doesn't hurt)
For emissions:
Update your OBDII tables to report "passed" for the EGR test. I will allow you to find this elsewhere.
https://www.evolutionm.net/forums/no...refer-mac.html
thanks
Old Oct 5, 2016 | 10:53 PM
Raceghost's Avatar
Looks good from my house.
Might give this thread look over:
https://www.evolutionm.net/forums/ev...-canister.html
Old Oct 6, 2016 | 04:04 AM
PauloPinho's Avatar
i read this thread and at the first time i have made this without problems
my problem now is the dual map if with that method i disable the egr systeme in both maps
my rom is 88580714 and i have 1 to address="103D" and 0 a address="1041"
so is the address 103D that i need change right?
Old Oct 6, 2016 | 10:11 AM
foxbat's Avatar
People still use Ecutek!! What's the point?
Old Oct 6, 2016 | 03:21 PM
Raceghost's Avatar
I have not played around with this ROM. From the ROM's I have, there is a global disable in the periphery bits. I was not aware that there was a rom patch that did it with both normal map and alt map settings.
Most of us use ECUFlash to do the editing. I have also not played with ECUTek.
Old Oct 8, 2016 | 02:36 PM
PauloPinho's Avatar
I remaped the car and the egr routine are disable, now the engine is very rich, it runs great at cruise but i have 12.2:1 between 2500/3000rpms in 3° gear and 14.5:1 in 4° gear :s
why i have this difference?
Old Oct 11, 2016 | 01:37 PM
PauloPinho's Avatar
Hi guys
wich is the difference between knock sun 3E and knock sun 26 in evoscan?
when i start the engine i have 1 knock sun 3E and the knock sun 26 stay at 0
gudmundur
AEM EMS
13
Dec 28, 2010 08:52 AM
pltek
Dec 10, 2007 11:51 AM
