help please!!!
Old Feb 23, 2006 | 11:33 PM
superman83199's Avatar
Registered User
help please!!!
Really need some help please... This is what's going on. Current mods are intake, catless down pipe, cat back, hks ssqv ver. 2. I just got done installing an o2 housing and header. I took the car out for a spin and it pulled sooooo hard! I check my boost and I was spiking at 23 and holding 22?? I don't know why its this high.?.? Before the install I was spiking 19 and holding 18. So Then I got on it again and at about 6000 rpm it felt like the car stalled for a sec. Followed by a backfire? I shifted to 3erd, got on it again, it started to pull hard, and then the same thing?? Then my check engine came on? What's going on?? The car still drives, and there are no funny sounds??? What is it?
Old Feb 23, 2006 | 11:47 PM
IEXCELR8's Avatar
Get it tuned asap and do not boost until then. Fuel cut most likely.
Old Feb 23, 2006 | 11:55 PM
dookgvr4's Avatar
way to blow up your new car
Old Feb 24, 2006 | 12:01 AM
spudlus's Avatar
You increased the amount of air flowing through the engine with the mods to your exhaust. That increased airflow is causing you turbo to spin faster and hence the rise in boost. If you have a MBC installed simply turn down the boost until you're able to get a tune to take advantage of your mods. The stall and backfire is the car going through fuel cut to protect itself from damage.
Old Feb 24, 2006 | 12:03 AM
Registered User
For sure I'm going to tune it within the next week.. What is fuel cut, what causes it?
Old Feb 24, 2006 | 12:09 AM
Registered User
That explains fuel cut/. Thank you very much for the quick answers guys.. Now I can sleep...
One more thing.. It will be tuned in about 1 week or so, and I won't drive it till then, do I need a boost controller??
Old Feb 24, 2006 | 12:12 AM
IE Evo's Avatar
Depends on the tuner.
Old Feb 24, 2006 | 12:19 AM
Registered User
Perfect..... Ill ask my tuner... Thank you!!!!
Old Feb 25, 2006 | 09:04 AM
evorace's Avatar
Grumbling, Backfires, and Higher Boost levels are normal when you take a cat off a car.
Old Feb 25, 2006 | 09:06 AM
f125gpracr's Avatar
Check for leaks.
Old Feb 25, 2006 | 09:13 AM
bernardo's Avatar
See this thread also:
https://www.evolutionm.net/forums/sh...d.php?t=186266
EDIT: Your CEL is most likely P0234 Overboost Condition
As the other thread states, stay off the boost, install the MBC.
Old Feb 25, 2006 | 09:14 AM
Ph3n1x's Avatar
Superman needs help?!?! WTF
