Is downpipe causing rpm float?
Old Feb 25, 2006 | 11:45 AM
KY's Avatar
KY
I was told that a 3" downpipe would cause RPM float. Is this true, because I have one sand I have RPM float.
Old Feb 25, 2006 | 12:21 PM
alloyic_rs's Avatar
whats rpm float?
Old Feb 25, 2006 | 02:24 PM
KY's Avatar
KY
When you get high up in the RPMs, but not redline and you let off the gas and press in the clutch to change gears and while the clutch is in the rpms continue to climb about another 500-1000 rpms.
Rnm's Avatar
Rnm
Are you talking about your idle stumbling? If so, I think the intake may be the problem if you weren't tuned for it.
*Edit: Nevermind.*
Old Feb 25, 2006 | 02:59 PM
xplhavoc's Avatar
NO!
Down pipe is mid range and will help out throttle responds as well..
Get one and test..
I have 3.25... and it works...
jeff
Old Feb 25, 2006 | 03:31 PM
4WS Tuning's Avatar
ur probably not letting off the gas competley when u shift...
Old Feb 25, 2006 | 03:34 PM
8urv8's Avatar
I have a 3" downpipe, and have never experienced that. Don't know what it could be.
Old Feb 27, 2006 | 06:45 PM
wicked-won's Avatar
all i noticed is that when i put my downpipe on it stayed in the powerband better for every shift i give it
kyoo
42
Jun 23, 2017 11:29 AM
cassidyb
Nov 21, 2009 07:05 AM
sloAZevo
Jan 1, 2008 04:38 PM
clovis112
23
Jan 11, 2005 05:15 PM
hesperus
May 24, 2002 12:14 AM
