Autostart questions
Old Mar 10, 2006 | 12:35 PM
evo4g63awd's Avatar
yes, i have a remote start on my evo. you need an extra key installed in the vehicle, just a tip though, shave off the teeth of the key before you install it into the immobilizer.
Old Mar 10, 2006 | 07:40 PM
SteveosEvo's Avatar
My turbo timer was built into the alarm/remote start. That way you know you will live it out of gear.
Old Mar 11, 2006 | 04:04 PM
BMan's Avatar
Or you can do like I did.
Mount the key box where you can reach it easily. If you park it somewhere that isn't safe, remove the key and disable the remote start. With the key out, the immobilizer works fine.
By-the-way, if the key is in the car, it can be hot-wired, you don't need to use the left-in key in the ignition.
The remote start is great with real cold and real hot weather to pre-heat/cool your car.
Old Mar 11, 2006 | 04:08 PM
phatman2600's Avatar
hahaha.... i had a friend who had a f-150 with autostart. The thing jumped into another car cause it was parallel parked on the side of the road.
Old Mar 11, 2006 | 04:15 PM
03redtype-s's Avatar
i think bypasskit.com has a module for mitsu that does not require leaving a kley in it. Might check that out!
Old Mar 11, 2006 | 04:17 PM
BMan's Avatar
Oh, I have the Compustar also. I only use the remote start with the turbo timer. If it isn't running when the door is closed/locked, the remote won't work.
Old Mar 11, 2006 | 04:20 PM
-Q-'s Avatar
-Q-
I had remote-start UNGO SR5000 on the yellow evo. Required a key, (programmed but uncut), in a module to be energized by the alarm. And now have an UNGO SR6000 in the blue one. Same module required. Works like a charm. Also installed the same alarm in my buddies STi a couple of months ago.
Old Mar 11, 2006 | 04:30 PM
bypass kit does have one but it will probably require a dealer scan tool to program it. Other than that you will need to use your key!!!
Spoolin4g63
Oct 2, 2014 08:03 PM
evoLuzN
Jul 1, 2011 01:09 AM
Mrxgrimreaperx
Lancer Troubleshooting
Jun 28, 2011 06:42 AM
Wallesasuaz
May 4, 2006 08:12 AM
