TopGear Evo VIII vs STi article
Old Apr 4, 2003 | 01:48 PM
JT-KGY's Avatar
Originally posted by Claudius
Yes, that's normal if you drive hard. Subaru brakes last even less!
I do not understand the brake difference...???
Aren't they both using brembo 4 pistons front and 2 pistons
rear??? Why would one fade faster than the other?
Diff pads?? Diff brake lines maybe?
Old Apr 4, 2003 | 02:09 PM
evomk8's Avatar
Originally posted by 97itr153
I'm willing to bet that on a typical road course or an autocross track, a stock USDM STi will lap faster than a stock USDM EVO.
If you look at "Best Motoring's" lap times from Tsubuka, you will notice that the JDM EVO and the JDM STi generally put in very similar lap times, with a VERY slight edge to the EVOs. However, the JDM STi and EVO produce similar bhp. The USDM STi's 29 bhp advantage and the USDM Evo's lack of a front LSD should skew the results in the STi's favour.
Tsukuba Lap Times of STOCK Evo V, VI, VII and New shape STi from recent "Best Motoring" tests.
http://www.tuningpt.com/store/tsukuba.htm
Notice how close all the lap times are! The spread from the 2nd fastest to the 2nd slowest is only 1 second.
1:04.65 Evo V RS
1:04.93 Evo VII RS
1:05.12 Sti Type RA Spec C (2001)
1:05.15 Evo VI RS
1:05.56 Sti Spec C (2003)
1:05.57 Sti (2003)
1:05.69 Evo VI GSR
1:05.72 Evo VI GSR TME
1:05.84 STi Spec C (2001)
1:05.93 Evo VII GSR
1:07.09 Evo V GSR
It's interesting how the fastest EVO and STi are NOT the latest versions. I couldn't find anything on the EVO VIII.
With the numbers being so close, it's simply the driver and the ever-changing environment at the time of the test. The variables are so numerous it's ridiculous.
I think that overall, even though the STi will have the extra gizmos and the bigger engine, the determining factor will be the driver.
Old Apr 4, 2003 | 02:47 PM
loudogz's Avatar
too bad US got the watered-down version of the EVO...
Old Apr 4, 2003 | 03:32 PM
evo1's Avatar
I don't agree with that .. for an everyday driver like myself ... no need for the other stuff besides the extra HP ... just more stuff that can break IMO. I'm sure both cars perform/ handle very similar ...
Old Apr 4, 2003 | 04:10 PM
97itr153's Avatar
It goes without saying that when we talk about lap times, we ALWAYS assume equal drivers. Otherwise, there is no point in discussing lap times. Period.
There are plenty of drivers who have the ability to extract a 1% difference in lap times between two cars. Take a look at the racing credentials of the test drivers at "Best Motoring" and you will realize how good these drivers are.
http://www.bestmotoringvideo.com/reviewers.html
Old Apr 4, 2003 | 04:21 PM
evomk8's Avatar
Point well taken.
I should have clarified the point is was making. Most of us (non-pro drivers) will likely not be able to tell the difference.
Old Apr 4, 2003 | 04:57 PM
nynguah's Avatar
I have a feeling that if one were to go for a ride in either vehicle around the track with one of the test drivers (or Rhys Millen for example), one would be powerfully motivated to rush out and purchase whichever vehicle had been tested.
Both cars are going to kick a$$ - it's going to be the whole Mustang vs. Camaro rivalry all over again
-Josh
Old Apr 4, 2003 | 05:01 PM
ru4real's Avatar
There could be differences in the brake pad compounds and operating temperature ranges, airflow around the brakes and wheels, cooling abilities of the rotors and calipers, brake force bias between the front and rear, GVW (the Evo is listed at 60kg lighter), unsprung weight, and weight transfer under braking.
Old Apr 4, 2003 | 05:09 PM
P2x's Avatar
P2x
Yeah, that's true. When I was watching that evo training vid that's floating around here they mention the design of the front spoiler and how it is conducive to directing air flow over the brakes. Things like that will definitely make a difference..
TaiwanEvo's Avatar
evo ROCKS!
Old Apr 4, 2003 | 05:29 PM
Rafal's Avatar
Originally posted by TaiwanEvo
evo ROCKS!
Sure man!
Foolproof
Feb 17, 2010 03:47 PM
1GTURNZ
Jan 26, 2010 11:31 PM
Jakeg97
Nov 5, 2004 08:37 PM
