Calculating Whp from Flywheel horsepower
Its not that hard to figure out guys, jeez. Drivetrain loss is pretty simple. With and EVO being AWD you are loosing between 21-24% of your horsepower before it reaches the wheels. Some people think that they are only loosing 20 horsepower through their drivetrain, thats just flat out retarded. Take my car for instance, EVO IX MR with a turbo back exhaust, 21psi and 93oct. It put 265.9 awhp down on the dyno. The EVO is greatly underrated from the factory, And I know Im losing alot more than twenty horsepower,
OK so ADD 23% and you get 347, and that is as close to MY flywheel horsepower I can get. So I figure I am losing 79hp through my drivetrain and all the rotational mass involved.
Everyones EVO dynoes in at different numbers, Every engine is unique, all drivelines are unique also. THERE IS NO WAY TO GET A PERFECT READING FROM THE FLYWHEEL UNLESS YOU REMOVE THE MOTOR. USING THIS PERCENTAGE WILL GET YOU WITHIN 10-15hp OF WHAT YOUR MOTOR ACTUALLY PUTS OUT. to some 10-15 HP is alot, not to me.
NOW DONT GET ME WRONG, WEIGHT OF WHEELS, TEMP OUTSIDE, ATMOSPHERE PRESS, WEAR ALREADY ON MOTOR AND DRIVETRAIN, AND A BILLION OTHER FACTORS INVOLVED. PUT IT THIS WAY, DO IT LIKE THE ENGINEERS DO IT, EVERYTHING STARTS WITH AN ESTIMATED GUESS.
someday hopefully some one with the resources will dyno just the engine then chassis dyno the whole car, till then it wil be nothing more than and educated guess at best and wild speculation at worst
Andenbre, even if someone did that, we wouldn't be able to apply it to all power levels, since there would be no evidence that the static drivetrain loss on that car would apply to other cars or be linear as power increases.
As I said, it is speed dependent. It would probably be easier to remove the engine and dyno that. Then re-insatall the engine and dyno the car at the wheels then you might get a rough indication of what magnitude it is.
Anyway, I don't think flywheel hp should be of concern to us folks. It's what it's putting down at the wheel that's important. And dynos that you put your whole car on measures the wheel hp anyway.
BTW, heavier wheels and flywheels do not have anything to do with tranny loss. Much in the same way that having a heavier car doesn't mean you make less power.
p.s. anyone tried different tyre pressures on a rolling road dyno? i read somewhere that losses at the tyre/roller interface is quite significant. But that's if you're interested in 10-15hp.
Originally Posted by x838nwy
Umm... I don't know how tuners do it, but gearbox losses are a bit of a black art. It's also speed related so it's all a bit complicated 'cos you include diffs and everything. I don't think it's anything like taking the flywheel/crank hp and then multiplying it be a number.
In anycase, I think the best thing is to dyno the thing before all the mods. Put the mods on then dyno again and subtract. If it's 216.4 then that's pretty lame and like many, I'd blame the intake (if it isn't the 'reloaded' version). I mean a test pipe shold at least give you somehting. I'd get the car back in its stock setup and dyno again. Also, as somebody said, it also depends on the dyno...
Considering from factory the power is meant to be 280bhp to the crank on 100 ocatne jap fuel. So I have 300bhp to the crank with a test pipe, cat back and intake on 95 octane irish fuel.
Originally Posted by funnyclub
Well if you think about it is it that lame?
jars121
Mar 12, 2017 08:10 PM
user 629782012
Jan 12, 2012 12:42 PM
awd, calculate, calculator, difference, drivetrain, evo, flywheel, horsepower, hp, loss, percentage, supra, wheel, whp, whpatw
