Shifting to 4th grinds @ 5k on after tranny warms up
Ive searched yes but havent exaclty found my anwser. shifting from 3rd - 4th above 5k is grinding even if i push in the clutch for a couple seconds. Ive noticed it doesnt seem to to it right but once the tranny get up to normal temps it will do it everytime. I did change my tranny oil to see if that helped and it did not. I switched to amsoil i know everyone is going to say try syncromesh which i plan on doing, but im thinking there is somethign wrong with the syncro. None of the other gears are doing it and i hardly ever even drive shifting into 4th at a high rpm. Or im wondering if it may be the clutch not fully releasing stock clutch 03 14k miles i adjusted the pedal and it did not help. Either way I guess i should take it to the dealer ive noticed there are tsbs on some of the syncros
Before you go and do anything drastic: check your tranny fluid level. If it is low, this could cause the problem. Also, try using synchromesh, this might make the grinding stop altogether.
evodrivesme
24
Aug 14, 2010 05:51 AM
RalliArtEvoVIII
13
Apr 27, 2005 06:34 AM
