anti loc light on!!!!
Old Mar 18, 2006 | 10:51 AM
cliffsevoviii's Avatar
ok im driving to the store doing about 35-40mph anti loc light comes on wtf? then when i start to slow down 10-15mph it starts flashing and at a complete stop it goes off? atf?????
Old Mar 18, 2006 | 10:54 AM
evo robert's Avatar
if it doesn't come back on, dont worry about it.
Old Mar 18, 2006 | 10:56 AM
vegasboy301's Avatar
+1
Old Mar 18, 2006 | 10:58 AM
it does!! its stays on when driving and flashes when coming to a stop!
Old Mar 18, 2006 | 11:01 AM
aboh6leenz's Avatar
I'd get it checked. Because usually when the abs light is on abs doesn't work. You might be happy it doesn't work but it's saved me from locking a couple times . I'm not sure but autozone checks cel's for your car I dont see why they wouldnt check the abs computer.
shiftdsm E's Avatar
def should check that out, make sure you have plenty of brake fluid and check the ABS fuse/relay. Otherwise it should be under warranty still have a dealer take a look
Old Mar 18, 2006 | 11:05 AM
anyone know where relay is located?
Old Mar 18, 2006 | 11:07 AM
shiftdsm E's Avatar
Should be under the hood, its location will be on the fuse box cover
Old Mar 18, 2006 | 11:14 AM
thanx guys
Old Mar 18, 2006 | 11:22 AM
GinuwineEvo8's Avatar
Its either a) your pads, b) your fluid .. Change your pads first and your fluid should be fine
8OhOh2
May 14, 2016 05:39 PM
cyabye
11
Feb 28, 2016 04:38 AM
Veronica
Apr 24, 2015 08:50 AM
allevolution
Aug 7, 2013 05:25 PM
