Help with Forge UNOS
Old Mar 23, 2006 | 02:53 PM
el producto's Avatar
Question Help with Forge UNOS
Okay so I ordered my MBC from evomoto and It arrived, but I'm not sure if mine already has the soft spring or stiff spring, It didnt come with anything else besides mounting plates.
If mine has the soft who can I buy the stiffer one from?
Old Mar 23, 2006 | 02:58 PM
sirloin1219's Avatar
damn talk to the person you bought it from. they should have supllied it. if not talk to mike@forge. havent seen him on here for awhile, but when i bought mine from lancershop it was missing the mounting plates, i talked to mike and BAM, he sent it to me free of charge. so i would see if you could find mike.
Old Mar 23, 2006 | 03:00 PM
thanks.
Old Mar 23, 2006 | 03:08 PM
steevo's Avatar
Install the mbc first and turn boost down all the way. If your boosting 15-16psi....you have the stiff spring. If your boosting 12psi or so, you have the soft spring. My soft spring was bronze, and my stiff spring is silver if that helps any. I had to get my stiff spring through a PM to Mike as well. Oh yeah...be sure to clean and grease first.
Old Mar 23, 2006 | 05:53 PM
thanks alot stevo
Old Mar 24, 2006 | 02:00 AM
Forge UK's Avatar
Mikes e mail .
mike@forgemotorsport.com
or call
407 447 5363 we will be pleased to help
Old Mar 24, 2006 | 09:43 AM
Angel@forgemoto's Avatar
Operators are standing by
Old Mar 24, 2006 | 02:04 PM
32 psi daily's Avatar
take the spring out and see how hard it is.
If you can't compress it easy with 2 fingers, it's the hard spring.
the difference between two springs are quite different, i think.
Old Mar 24, 2006 | 03:16 PM
sweeett thanks.
Old Mar 25, 2006 | 02:32 PM
Installed and works perfectly.
