p0134
Old Apr 14, 2006 | 12:48 PM
czp25's Avatar
p0134
After changing the hotside, the O2 housing and the exhaust manifold I got the P0134 code. The O2 secor is pluged in and everything seem to be running normal. The car pulls way stronger and I'm happy with the results. Do you guys think I might have damaged the O2 trying to get it out from the old housing?
Any thoughts?
Old Apr 14, 2006 | 02:03 PM
kevo's Avatar
I used to have p0134 and p0171 on my 03 Evo which cause by a damaged front o2. Fix the codes by replacing the front 02 sensor.
Old Apr 14, 2006 | 02:09 PM
czp25's Avatar
Is it dangerous to drive with a faulty O2 for a while untill I get a new one?
Old Apr 14, 2006 | 03:30 PM
Rnm's Avatar
Rnm
Not really, but you will be wasting a LOT of gas.
Old Apr 14, 2006 | 03:34 PM
s2KMR's Avatar
yup.. running very rich
Old Apr 14, 2006 | 03:45 PM
mikesevo8's Avatar
Yup - a couple passages from the manual:
Code: P0134 Heated oxygen sensor circuit no activity detected (sensor 1)
FAIL-SAFE FUNCTION REFERENCE TABLE
When the main sensor malfunctions are detected by the diagnostic test mode, the vehicle is controlled by means of the following defaults.
Heated oxygen sensor <front>
Air/fuel ratio closed loop control is not performed.
So, at WOT your car will feel "normal", because it runs open loop at that time.
But with the O2 not working, the car defaults to the open loop maps, so you will burn gas like mad.
O2 sensors are more sensitive than people think.
Do yourself a favor. Search for a aftermarket replacement sensor.
It will be less than half the price of the OEM.
Old Apr 14, 2006 | 03:48 PM
czp25's Avatar
thanks for the replys
Old Apr 14, 2006 | 03:52 PM
czp25's Avatar
Even with the computer having a reflash, it will still go to that open loop map?
Old Apr 14, 2006 | 04:54 PM
czp25's Avatar
Well I found an aftermarket O2 sensor on oxygensensors.com for 99.95. Can't find them for any less than that
GodRealm06
Jul 9, 2015 02:36 AM
slammedndirty
Sep 17, 2013 11:23 PM
EvoJoeIX
Dec 8, 2010 10:32 AM
EvoDan2004
Mar 24, 2010 10:23 AM
zeus1
12
Jan 13, 2009 11:12 PM
