redline heavy shockproff
Old Apr 21, 2006 | 12:07 PM
bluebyu36's Avatar
is redline heavysockproff okay for the trany?in an o3 evo,i know it,s been talked about a million times i just dont want to mess anything up.
Old Apr 21, 2006 | 12:09 PM
Waz996's Avatar
what on earth is a redlineheavyshofkchflfirfporff?!!!
ok ok.. search the forums.. search the forums..
wael
Old Apr 21, 2006 | 12:12 PM
Dero's Avatar
Are you looking for tranny fluid or differential fluid?
I have used Redline heavy shockproof in my front dif for about 12,000 miles now. No problems at all.
A lot of people on this site have said that the Redline fluids will lead to busted difs, but I think that most busted difs are from abuse.
I also have Redline fluid in my rear LSD. It was changed the same time as the front dif.
Old Apr 21, 2006 | 12:16 PM
Ev0ikon's Avatar
The only place you can use the RL ShockProof on the Evo is the TransferCase. Not the Tranny. And even then, stick with Mitsu's Diaqueen LSD fluid.
Old Apr 21, 2006 | 12:18 PM
bluebyu36's Avatar
thanks ill just wait i wont use it
Old Apr 21, 2006 | 12:37 PM
twinscrewed's Avatar
For the Transmission....No. For the Transfer Case and Rear Diff.....Yes.
Syncromesh (GM, Pennzoil, or BG) are what you want for the trans.
Old Apr 21, 2006 | 12:43 PM
bluebyu36's Avatar
what weight pennzoil? twinsrewed?
Old Apr 21, 2006 | 01:15 PM
jmartinez1170's Avatar
I got it in my car it works great i dont see it any better then anything else out there all the same from my point of view i have used 4 kinds of trans fluid in my car, i think im going to stick with just the reg. GL4 Trans fluid sold at many car shops.
Old Apr 21, 2006 | 01:31 PM
Ev0ikon's Avatar
The only thing I didn't like about RL ShockProof is that it's so d@mn thick and takes forever and a day to drain.
Now I do it with Diaqueen and Do it often
Old Apr 21, 2006 | 03:34 PM
gsrboi80's Avatar
Penzoil Syncomesh (It comes in a yellow bottle)
Old Apr 22, 2006 | 08:31 AM
Its just plain Pennzoil Synchromesh. http://www.pennzoil.com/products/gea...cro_fluid.html
Old Apr 22, 2006 | 08:38 AM
kimletrim's Avatar
Registered User
If Shockproof is used in the tranfercase or rear diff, it is adviseable to use a friction modifier.
Old Apr 22, 2006 | 08:43 AM
WrX Kila's Avatar
I would not use REDLINE. I used it in my car once. When I took the car to the dealership for trannt work, the tech told me that it cooked on the gears. I am using stock. I have 44000miles on my car and I have yet to change the rear diff fluid. I am going to be replacing it shortly.
Old Apr 22, 2006 | 08:51 AM
evocanival's Avatar
sorry to steal your post, but is dia queen ok to use for the rear diff?
thanks, Jovan
Old Apr 22, 2006 | 09:11 AM
I give the Heavy Shockproof a big . It saved my new t-case when the fill plug fell out on the drive home from having it installed (50 highway miles). A little less then 1/2 the fluid spilled out, yet the t-case is perfectly fine. No doubt because of how thick the Heavy Shockproof is. If it was lower viscosity, more would have spilled and probably led to a broken t-case.
