timing mark on block or cover?
Old Apr 29, 2006 | 06:45 AM
drewblueeye's Avatar
I recently installed my hks 272 cams and when i hit 3000 to 4000 rpm i get a small vibration. thought about it and thought about it and i think i got it!!! when i checked my timing on the cover before i started it was 3 degrees BTDC, but when i put it back together i didnt go by that i went by the timing mark on the engine block to the crank (the mark under the timing pulley) cuz i changed my timing belt.... so my question is, did i set my timing to TDC and not 3 degrees BTDC? and if that is the case that means my crank is off one tooth, which then means that my balance shaft is off one tooth, and that could be my vibration. Right???
Old May 1, 2006 | 03:21 PM
Jamie@WORKS's Avatar
The balance shaft being off/out of phase is my first guess.
marinejensen
16
Jul 7, 2015 07:18 AM
memphis raynes
Nov 18, 2013 05:02 PM
zanelefko
12
Nov 20, 2011 12:37 PM
Thomasevo
Apr 20, 2010 04:49 PM
Ksyrium11
Jun 11, 2007 06:09 AM
