evo ix?
Old May 2, 2006 | 10:26 PM
KINGEVO7's Avatar
The boost that we run stock has nothing to do with when the stock BOV begins to leak. They are unrelated measurements. Look around, and you'll see I'm not the only one who has personally pressure tested the stock BOV and had it begin to open at 13psi...
ok...I am not argueing by the way just getting more info on the subject .
Old May 2, 2006 | 10:28 PM
Warrtalon's Avatar
Originally Posted by KINGEVO7
so let me get this right, when the stock evo8 boost to 19psi and tapers to 16 psi it never made it cause it leaked at 13psi on most if not all evo8s?
No, that's not how it works. You don't understand what "leaking" means. This doesn't mean that at 13psi all boost ceases. It means that at 13psi, the valve begins to open, which leaks out SOME boost, thus requiring the turbo to work harder to maintain the prescribed boost levels. Just like anyone with a boost leak anywhere in the boost system, the turbo has to work harder to maintain the boost, and you wouldn't even know the difference, since your boost gauge would still read normal while the turbo is blowing hot air just trying to keep up.
On much larger leaks, you can notice symptoms such as large boost drops or whistling noises, but on a small one like when the BOV begins to open, you wouldn't know the difference.
TariqEvo
Jul 17, 2017 07:21 AM
TurboTylerIX
35
Sep 1, 2016 08:27 AM
DaEvoBull
Jan 22, 2013 06:53 AM
05VIII
64
Jan 25, 2011 12:13 PM
rizalhoo
Oct 3, 2003 06:05 AM
