HELP!!! Transfer Case Fill PLUG
Old May 3, 2006 | 06:29 PM
damianhindley's Avatar
Originally Posted by LilyK
I'm gonna ask another question. I changed the tranny fluid last month. And I felt like i'm getting a lot worse gas mileage. I used BG Synroshift I. I pump til the fluid start coming back out.
Was it because I changed to 18 inches wheels. The lost in mpg is quite noticable. Amost 1/4 gas tank gone for 33 miles street driving!!!!...Not even driving it hard....Not in boost range. Stock ECU, no flash, only mod is Turbo back exhaust. !!!!!
Dude thats just the gas station robbing your *** with the higher prices. The more the gas cost the more i watch my gauge (like it helps any), but yeah i always feel like a i get bad gas milage when the price is high
Old May 3, 2006 | 06:30 PM
BMan's Avatar
Originally Posted by LetItBreath
I find a good system with stuck bolts is to use pb blaster the hit the bold on the head with a hammer to shock it. The schock helps loosen it up. then try the blaster again if you have to. Theres always a way man
You don't want to hit it too hard, it is aluminum! ( the tranny, not the bolt)
Old May 3, 2006 | 06:33 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
Yea, maybe I should clarify, Dont SLAM the thing, just hit it. Just enough impact to vibrate it in place.
Old May 3, 2006 | 06:53 PM
bpclements's Avatar
I always use a 1/2" breaker bar along with a 1/2" drive socket. Take care not to over torque the plugs when reinstalling. The torque specs for both the tranny and transfer case plugs is 23ft/lbs.
Old May 4, 2006 | 04:39 AM
kekek's Avatar
lefty loosey, righty tightey...
always works for me
Old May 4, 2006 | 09:43 AM
EVOIX4me's Avatar
always works for me
this isnt pre-school .. Just use the breaker bar , and if you dont know what direction to turn the bolt , i would not be doing it myself
Old May 4, 2006 | 08:56 PM
trinydex's Avatar
Originally Posted by BMan
I just used the old flesh mallet to pop it loose.
works for me every time... you gotta give it impulse, constant force ain't gonna help you
Old May 4, 2006 | 09:14 PM
Kayaalp's Avatar
Here it is in 3 easy steps...
Step 1: Spray a little BreakFree CLP, Remington RemOil, 3-in-1 (or whatever penetrating oil you prefer) on the threads. For the love of God, don't use WD-40. That's a solvent...not a penetrating oil.
Step 2: Tap the head of the bolt lightly with a small metal hammer. This will help release the bolt.
Step 3: Use a box-end wrench (NOT a crescent wrench or socket wrench) to break the bolt. If you need that extra "oomph," then lightly tap the free end of the wrench with your palm or even a small mallet.
Step 4: If you've already stripped/deformed the head of the bolt past the point of no return, use a Vice Grips...but make sure you use the GRIPPING kind (NOT the clamping kind).
If none of those work, then just bite the bullet and take it to a shop. The last thing you want to do is strip out the aluminum threads on the t-case.
Emre
Old May 4, 2006 | 11:50 PM
trinydex's Avatar
hmm... what do you recommend for breaking the drain plus then... that thing is a 24mm... i O.O i don't have a 24mm box end :\
which is my indirect way of asking... why no use sockets for breaking bolts?
Old May 5, 2006 | 05:29 AM
kekek's Avatar
B/c sockets have a tendency of slipping off and rounding off bolt heads, especially when used with a ratchet since the ratchet is not inline with the bolt head, it is raised. It really depends on how much torque needs to be applied. Impact guns are different since the force is axial with the bolt.
Box end wrenches are great b/c the force is applied in line with the bolt head. I have found it a little difficult to get a box end in to loosen the rear diff and TC drain plugs and used a 24mm 12 point socket with 1/2 drive ratchet. I didn't have any problems breaking them loose.
Old May 5, 2006 | 01:05 PM
trinydex's Avatar
i guess i asked because most of the time sockets have more contacting faces to the bolt but i wouldn't disagree with what you said at all. if you use the exact size of a box end the fit is quite tight.
Old May 5, 2006 | 01:42 PM
sonicnofadz's Avatar
This is such a sad thread...
Old May 5, 2006 | 06:13 PM
xXxJIGGAxXx's Avatar
15/16" works if you have that.
chaotichoax
32
Feb 11, 2020 09:00 PM
junk1337
Evo X How Tos / Installations
60
Jul 22, 2016 03:27 PM
TouringBubble
Oct 23, 2013 10:59 AM
evoDON
May 17, 2013 08:31 AM
StreetThisEvo
22
Jul 23, 2012 03:48 AM
