Which replacement clutch is closest to stock feel?
Old May 24, 2006 | 05:46 PM
  #31
MrMejia's Avatar
for those of you that "dont know" what clutch you have cuz' you baught a used evo then you can find out just by removing the black rubber groment on the bottom of the bell housing on the tranny. You have to remove the undertray first(if you dont have it then it will be super easy). Once you have that lil thing out then peek in there and check it out. stock clutch is usually dark grey pressure plate.
Old May 24, 2006 | 05:51 PM
  #32
occultworks's Avatar
Good info MrMejia, thanks!
Old May 24, 2006 | 06:02 PM
  #33
DrSmile's Avatar
Originally Posted by djmikeymike
back OT........... how much power is the stock clutch good for? im talking on the street no drag raceing
The stock clutch works fine at 300 wheel ft-lbs (Mustang dyno) on my car, just DON'T TRY TO LAUNCH THE CAR! Unless you like toasty clutch smell, in that case go right ahead...
I'm dreading making the ACT switch because I still have a bigger left leg from my DSM ones
Old May 24, 2006 | 06:12 PM
  #34
dbdude's Avatar
Im in the process of buying a exedy stage 2 cerametalic. I guess i better start working out my left leg in the meantime. Cant wait to do launches!!
Old May 24, 2006 | 06:29 PM
  #35
su37su's Avatar
What if you have a new IX, just curious why my clutch is so hard and I've been in other IX's and there clutch is so soft.
Old May 25, 2006 | 03:08 PM
  #36
djmikeymike's Avatar
The reason im asking i want to do cams, 20g, o2 and licp. Just want to know if im going to a new clutch after these mods.
Old May 25, 2006 | 03:25 PM
  #37
Danny23's Avatar
just remove the restrictor pill from the slave cyl., put a ss clutch line on and keep the stocker.
austin_davee
Dec 29, 2016 08:51 AM
EvoOtto
11
Jun 28, 2016 12:37 PM
SsZERO
36
Sep 24, 2010 07:10 AM
Assassin
10
Dec 3, 2005 05:57 PM
Go_Lancer_Go
Lancer Tranny/Drivetrain Tech
17
Jul 23, 2005 07:09 PM
