Info on best fulids to use......
Old May 30, 2006 | 08:42 AM
binx811's Avatar
So I bought my 03 evo used back in January and my buddy was telling me that I should have all the fulids drained and replaced since i don't know how the owner before treated the car. My question is which fulids should i use for the TC & Transmission? Any info would be great! thanks ahead of time.
Old May 30, 2006 | 08:44 AM
Aux.'s Avatar
Dude.... look in the search function. This topic has been covered one million times. I am sure you could find something if you looked .
Old May 30, 2006 | 08:46 AM
WagsEvo's Avatar
Use water.
Actually, search and you might find better ideas.
Old May 30, 2006 | 08:54 AM
binx811's Avatar
thanks!
Old May 30, 2006 | 12:46 PM
kreionic's Avatar
Motul Personally the best out there but everone will have there own favorites. I chaged all my fluids to motul and %100 difference
Old May 30, 2006 | 12:53 PM
vboy425's Avatar
Royal purple or BG synchroshift for the Tranny, Transfer and rear dif use OEM Mits diaquen LSD gear oil
Old May 30, 2006 | 01:18 PM
bigfishs's Avatar
+100
Old May 30, 2006 | 01:58 PM
trinydex's Avatar
search transmission fluid or tranny fluid.
then search diff fluid and then differential fluid.
then search gear oil pump.
motul sucks by the way. i haven't ever had a worse transmission fluid in my transmission. it's worse than stock diaqueen. the way i know is that all my shift bushings are solid which means i can feel everything that goes on in the cables. motuld sucks ***. two bottles of bg and a bottle of redline mt90 is perfect. i think i actually might have damaged my tranny running the motul for the 100 or so miles that it was in.
for reference i have a 5 speed. i can't speak for a 6 speed.
binx811's Avatar
thanks for writing guys, my bad though for not looking first.......but thanks again!
Old May 30, 2006 | 02:12 PM
Danny23's Avatar
BG syncroshift in trans.,diaqueen in t/c and diff. best combo you can use period.
silverguy
Feb 23, 2012 07:47 AM
5LEEPERISAH23I
10
Oct 18, 2009 11:09 AM
Spunkysandoval
Jul 25, 2009 06:15 AM
shin07
Jan 9, 2008 07:49 PM
Loaked
22
Jan 5, 2007 05:09 PM
