Exhaust system changed! What next?
Hi
on my 04 evo 8 It's installed Magnaflow cat back system (3" SS tubing, 4" p-SS tip) (already on the car when I bought), but I have standard OEM air intake system.
What's are yours suggestions about intake system for max. overall performance (stay on OEM or upgrade)?
thanks
thanks
Originally Posted by SKILMATIC
IMHO stay with the oem setup with a drop in. If you want to go aftermarket I would go with a induction box (ie ARC).
what do you mean with "drop in"?
anybody knows what is power increase with that exhaust system?
Ok
which system is better?
1.
http://cgi.ebay.co.uk/Mitsubishi-Lan...QQcmdZViewItem
or
2.
http://cgi.ebay.co.uk/K-N-Air-Filter...QQcmdZViewItem
1.
or
2.
#1 get a boost gauge. then either get a flat panel k&n stock replacement or buschur intake filter kit (will need tune for BR kit), forge mbc, walboro 255, forge/JDM MR BOV and tune. that will get you a smooth running beast. the buschur intake kit has been found to provide 11hp over the flat panel (search buschur intake vs k&n) but at the expense of increased intake sound. i have the buschur kit and the sound is definately noticeable but not bad.
OK
boost gauge I have (Blitz turbo timer with boost reading).
I will go after K&N "drop in" (I have to change the filter)
Also I will probably go after Hallman MBC. Could anybody tell me what is still the safe boost with that settings (everything else is stock)? Is it 21 psi too much?
Also please tell me if I upgrade with MBC, can I remove hose lines between solenoid and wastegate (with restrictor pills inside) and replaced them with usual hoses without that restrictors?
In first stage I will not change BOV and fuel pump. Or should I have to change it? Is that to risky?
How much horse power should I get with that settings?
thanks
thanks
FS[Northeast]: Custom 4" Speed Density Intake + SS Heatsheild
MisUnderStood
Dec 23, 2015 11:18 AM
CeeNiK
10
May 31, 2005 10:21 PM
Derek888
Jan 26, 2005 07:46 AM
