my intercooler pipe came out
Old Jun 18, 2006 | 10:44 AM
TY3IK's Avatar
Question my intercooler pipe came out
Hey guys yesterday I was driving pretty crazy and my lower intercooler pipe came out I have injen pipes on my 06 MR. Its not that pretty to be under a new car and trying to fix the problem. Is there anything I can do to it so it wont come out again???
Old Jun 18, 2006 | 10:47 AM
MondoBongo's Avatar
I hear that NAPA constant torque clamps can solve this problem.
https://www.evolutionm.net/forums/sh...d.php?t=175772
there is the size listing.
Silk's Avatar
T-bolt clamps
Old Jun 18, 2006 | 11:26 AM
Exciting News's Avatar
You broke your cherry!
Old Jun 18, 2006 | 12:17 PM
SlowCar's Avatar
degrease those joints real well, spray some "tackifier" like hair spray and then clamp it down with some high torque clamps www.mcmaster.com, part #5661K(11-26). T-bolts MAY introduce a slight leak under the supporting band
does the injen pipe have a rolled bead at the joint?
Old Jun 18, 2006 | 01:12 PM
TY3IK's Avatar
ye it does
Old Jun 18, 2006 | 03:56 PM
Lgkaos's Avatar
Veteran: Air Force
I experienced the EXACT same problem on my IX w/Injen's LICP. It's obviously designed for the VIII and doesn't fit the IX because of the different turbo-outlet pipe.
I took mine to a local import shop and they extended the LICP by welding a longer piece onto the endtank side of the LICP. Now the Injen pipe actually touches the endtank on the intercooler and touches the turbo-outlet pipe as well. Clamped it w/T-Bolts as well for extra insurance...no probs since.
Old Jun 18, 2006 | 04:01 PM
ballistic speed's Avatar
try to avoid adhesive sprays cuz when those sprays get hot, they can slide around too, and use some t-bolts and degrease that thing as best you can, the pipe and the coupling
Old Jun 18, 2006 | 06:07 PM
WhIte06evO9's Avatar
yea dont worry i had the same problem with my 9 driving off the turnpike and my UICP blow off the throttle body pissed the clamps they used are **** so i just used a reg t-bolt clamp hopefully that will work till i get my custom pipes from pruven or ams intercooler piping
Old Jun 18, 2006 | 06:13 PM
cdupont03's Avatar
I have an evo and injen pipes and I have had problems with them popping off. I just had my LICP blow off on my way home from work the other day. I couldnt make it home cause I had no tools, so I had to pay a shop $70 to fix it and put new clamps on it, only to have it blow off 1 hr later. And the couplers suck by the way
380EVO
Evo X Dyno Results
Sep 14, 2016 07:01 AM
rcheung
50
May 6, 2009 08:18 AM
SophieSleeps
Jul 21, 2007 12:12 AM
PHILLY EVO
12
Aug 7, 2004 06:10 AM
Deceit
12
Apr 9, 2004 04:58 PM
