One touch up-down Windows?
Old Jun 19, 2006 | 10:11 PM
Ink's Avatar
Ink
Is there any way to make the front two windows roll up with one touch and if possible make them both roll down with one touch?
Old Jun 19, 2006 | 10:42 PM
kf6ytc's Avatar
http://www.audio-discounters.com/cs-5502.html
Old Jun 19, 2006 | 10:55 PM
EvoRicer's Avatar
If I wanted my Driver's side to control all 4 windows with one touch would I need to buy 4 of those?
Old Jun 20, 2006 | 09:27 PM
xmaciek82x's Avatar
I would like to know as well
Old Jun 21, 2006 | 09:47 AM
jdub765's Avatar
yup, you need 4 of them, one for each window.
Old Jun 21, 2006 | 10:12 AM
JaReDbOy's Avatar
how would you then link all 4 together to do a one touch, all four down?
Old Jun 21, 2006 | 02:27 PM
Andrew LB's Avatar
One thing i really missed about my audi was the ability to just touch all 4 buttons once on my drivers door panel and all windows would roll down at the same time.
.... i gotta get these.
Old Jun 21, 2006 | 02:39 PM
Inspite's Avatar
My Python 881xp alarm was installed with a modual that on touches the front windows. I would have needed an extra module for the rear, but it can be done.
Old Jun 21, 2006 | 02:46 PM
deZerteVo's Avatar
Directed Electronics sells window modules that will allow you to one touch up / down your windows... with and without an aftermarket alarm... and roll up your windows when you arm it too. I had them on another vehicle and work awesome. Can't wait to put it on my eVo
Old Jun 21, 2006 | 03:02 PM
AhmadHasib's Avatar
with the one touch up down window, you press it down a little, windows role dow,, press it down even more, gives a sorta "click" to let you know its in automatic mode. What if you only want the windows half down (smoking purpose) how would this do that?
Old Jun 21, 2006 | 04:12 PM
kmcconn9's Avatar
With the DEI product you would just have to press the opposite direction to get the window to stop moving.
I had this on my eclipse and did my sunroof and front windows.....
Old Jun 21, 2006 | 08:00 PM
stpracer's Avatar
I added two Autoloc WC1000 control units to the front windows on my Evo. One touch up and down. They work perfectly. The only tough part was trying to find a place to put the control modules. If you use the Autoloc units I can dig up my wiring diagram again.autoloc
Old Jun 26, 2006 | 10:39 PM
jdub765's Avatar
The window modules work with the factory window switches. If you hold the switch down for less than half a second, then it'll roll the windows all the way down. If you hold them longer, then the window switches work normally. The switches w/ the click become regular switches.
To stop the auto down or up travel click it again in the same or opposite direction.
Old Jul 19, 2006 | 04:31 PM
JouerEVO's Avatar
Are these units plug and play?
Old Jul 20, 2006 | 07:13 AM
BillAce's Avatar
THe Directed 530T must be hardwired. One module will work 2 windows up/down so 2 530T's are needed for all 4 windows.
